Need advice on gen 4 engine build - Kawasaki ZX-10R.net
post #1 of 7 Old 12-08-2014, 01:13 AM Thread Starter
Jstamm33's Avatar
Hello everyone,
So I need to squeeze another reliable 10-15 horsepower out of my 2011 and I'm pretty sure that apart from nos, engine work is my only option. It has 1/6th throttle tube, bmc race filter, all emissions removed and Pair valves blocked off, guhl ecu flash, pcv with custom tune and Austin racing slip on exhaust (no cat). The secondary throttle bodies are still in. The bike made 178 on the Dyno. Should I just do a thinner headgasket and remove the secondary butterflies, then retune? Should I do race cams and port and polish? What are the gains? Trying to spend less than 3k or around there n
Jstamm33 is offline
post #2 of 7 Old 12-08-2014, 04:52 PM
Since you're in Long Beach, I'd simply drive over to Attack Performance in Huntington Beach and tell them what you're after and your budget.
They'll be able to put a package together for you that should meet both your goals and budget.
ZX10RArcher is offline
post #3 of 7 Old 12-08-2014, 06:17 PM
The Pace
scout's Avatar
What is your application goal.
scout is offline
post #4 of 7 Old 12-08-2014, 07:36 PM
Pretty much stated that in the very first sentence.
post #5 of 7 Old 12-09-2014, 05:09 PM
BOOSTED's Avatar
Thinner head gasket might gain you a negligible 2hp. I would talk to a local bike specialist and have the head decked, thinner head gasket, port work, maybe an intake cam and have them degreed to what you are looking for.
2016 Ninja H2 - CANADAS Fastest 1/4 - 8.34 at 169mph - 208.4mph in the mile. Brocks Performance Stage 2 Package, MC Cycle works Intercooler, Full Polished Slash-Cut Exhaust, DNA Filter, PC5, Brocks Lowering Links, Brocks Front Strap Kit, BST Rim, Adams Performance Swingarm 7-11", Zero Gravity Corsa Windscreen, Evotech Radiator Guard, Evotech Fork Sliders, Yoshimura Tail Tidy
2011 ZX10R - SOLD
BOOSTED is offline
post #6 of 7 Old 12-09-2014, 06:07 PM
dricked's Avatar
I was waiting to see what advice he had other than to switch to amsoil and run it till she blows.
dricked is offline
post #7 of 7 Old 12-09-2014, 08:23 PM
gazx10's Avatar
ported a gen 4 head with .015 deck, .45mm hg, cnc vj. customer assembled with race int. only degreeing cams for midrange over top end as he rides in mountains. made 193 sae on pump gas. i would leave flies in on those larger tb's.
gazx10 is offline
Gen 4: Turbo build need some advice 1upmoto Performance and Tech 10 11-06-2014 03:43 PM
What the hot heck? Revving problem on new engine build. Huey130 The ZX-10R 4 10-17-2013 09:21 AM
Gen 1: Engine build Question! bodymanruss518 The ZX-10R 8 07-09-2012 08:25 AM
Gen 1: Zx10r engine build twowheels123 Performance and Tech 13 02-21-2012 04:11 PM
Race Engine Build axo250 Performance and Tech 30 05-05-2007 07:17 AM
