Gen 4: 2011-2015 Myth "Confirmed" Dyno Graphs from Grave's Full system compared to Slipon - Kawasaki ZX-10R.net
post #1 of 12 Old 05-31-2013, 08:41 AM Thread Starter
PatrickG's Avatar
Images: 15
Well..
It is true!! No top end power is to be gained when switching from a slipon system to a full system. Bike made within .75 HP of each other on the top end. Big gain in the midrange from 5500-11000 RPMs, with a little gain from 11000-12000
GUHL reflashed ECU with 14000 Rev limiter, PCV mapping, secondaries pulled out. Bike is stretched almost 8".
I the prior thread, Brock's was the most accurate in their dyno graphs comparing a stock, slipon and full exhaust.
Grave's showed power gains everywhere, so I don't know the exact data behind their dyno pulls..
The BLUE line was last July 27, 2012, 90 degrees outside. Slipon system
The RED line is yesterday May 30, 2013, 87 degrees outside. Full System
I put up a copy of the barometic data also from last year and yesterday. Almost identical so very little difference in air. Look at the DATES.. not the file names, we didn't change the file names before I took the pictures.
So.. there it is!!
And a youtube video....
http://youtube.com/watch?v=Yu7A_9eXpLI
Name:	Gen4 Graves Dyno Comparision.jpg
ID:	202066   Click image for larger version
Name:	Weather slipon.jpg
ID:	202074   Click image for larger version
2005 ZX-10R Akrapovic Ti Evo 2 w/CF LOR can, PC3 with custom map, Factory Pro velocity stacks
2009 ZX-10r Full Gen4 Brock's SS exhaust with CF 14" can, PC3, Secondary Butterflies Removed, Kawasaki Race Exhaust Cam, My Own TRE, Degreed Cams 109/108
2011 zx10r Lower'd 2" Frt & Rear, Stretched 8", Graves CF slipon, GUHL Flashed ECU
PatrickG is offline
post #2 of 12 Old 05-31-2013, 09:02 AM
Awesome post. Good luck with the new set up. Keep us posted.
a2g2nv is offline
post #3 of 12 Old 05-31-2013, 09:24 AM
fireman69's Avatar
Is the mid range bump we see about 3-4 hp?
fireman69 is offline
post #4 of 12 Old 05-31-2013, 09:35 AM
thundercoupe9's Avatar
Looks about 7hp gain at 7k rpm
thundercoupe9 is offline
post #5 of 12 Old 05-31-2013, 09:36 AM
Was the bike stretched on the first dyno session with the slip on only?
post #6 of 12 Old 05-31-2013, 02:31 PM Thread Starter
PatrickG's Avatar
Images: 15
Both times it was dyno'd it was stretched the same length.
PatrickG is offline
post #7 of 12 Old 05-31-2013, 05:44 PM
BOOSTED's Avatar
Thanks again for doing the comparison.
2016 Ninja H2 - CANADAS Fastest 1/4 - 8.34 at 169mph - 208.4mph in the mile. Brocks Performance Stage 2 Package, MC Cycle works Intercooler, Full Polished Slash-Cut Exhaust, DNA Filter, PC5, Brocks Lowering Links, Brocks Front Strap Kit, BST Rim, Adams Performance Swingarm 7-11", Zero Gravity Corsa Windscreen, Evotech Radiator Guard, Evotech Fork Sliders, Yoshimura Tail Tidy
2011 ZX10R - SOLD
BOOSTED is offline
post #8 of 12 Old 05-31-2013, 06:03 PM
yes, thanks for posting this up
post #9 of 12 Old 05-31-2013, 06:25 PM
Wesley8711's Avatar
One of the better comparisons I've seen where you get the conditions as close as possible when comparing to the previous dyno run. Nicely done man
Wesley8711 is offline
post #10 of 12 Old 05-31-2013, 10:47 PM
is it me or is the air-fuel significantly less consistent with the full system (in terms of making direct comparison). Seems to me there may be more to be gained yet with the full system if the fueling were as stable as with the slip-on......
mikstr is offline
How to "burp"/purge the cooling system? Jay Performance and Tech 6 09-22-2010 11:02 PM
Great Deal on eBay... "full Akrapovic system" Check it out!!! PatrickG The Out House 15 01-19-2010 10:09 PM
"PLUG AND PLAY" Projector Retrofitting System: Product R&D Request aavhidsystem ZX-6R & ZX-6RR Archives 47 11-13-2009 02:42 PM
Since "dyno shootout" won't post results........ FredE Performance and Tech 16 05-11-2008 02:52 PM
Do i "need" a power commander with a muzzy slipon? RichTJ99 The ZX-10R 2 04-13-2004 07:30 PM
