My OEM horn trigger and my aftermarket horn - Kawasaki ZX-10R.net
post #1 of 14 Old 04-08-2009, 11:10 AM Thread Starter
russell's Avatar
So I originally attempted to hook this up about a year ago with no luck, so I gave up.
Well I got a new roommate and coincidentally he is an electrical engineer, and he has all the tools I need to do some electrical investigation.
Basically what we found out is that the circuit that runs from the +12v from the battery to the OEM trigger is good, but after going through the OEM trigger's circuit the voltage is degraded to 5.5 MILLIVOLTS!
My question is how can i fix this? I don't want to install another switch, because I would really like to use my OEM trigger, but how I replace/upgrade the cables and/or the trigger itself?
russell is offline
post #2 of 14 Old 04-08-2009, 10:24 PM
the connection at the stock horn - use that to power the coil on the relay.
if the stock horn doesn't work you have problems....
cdk83 is offline
post #3 of 14 Old 04-08-2009, 10:41 PM
nickalltogether's Avatar
you can use the output from the horn to trigger a relay for the new horn :)
nickalltogether is offline
post #4 of 14 Old 04-09-2009, 12:37 AM Thread Starter
russell's Avatar
right. that's what i'm trying to say. the output of the stock horn is 5.5 millivolts. it needs 12 volts.
russell is offline
post #5 of 14 Old 04-10-2009, 07:01 PM
lenshead's Avatar
Sorry to state the obvious, but have you checked your fuses????
lenshead is offline
post #6 of 14 Old 04-10-2009, 07:04 PM
Wouldn't your friend know the answer to this if he is an electrical engineer
killersrt is offline
post #7 of 14 Old 04-11-2009, 03:21 AM Thread Starter
russell's Avatar
well we checked the resistance and when the circuit is completed it goes from infinite ohms to 0 ohms, which means a circuit is completed. which means that the fuse must be in tact.
russell is offline
post #8 of 14 Old 04-11-2009, 03:22 AM Thread Starter
russell's Avatar
i would like to think so, but he's not familiar on how to replace or repair the horn-switch circuitry on the 2005 zx-6r
russell is offline
post #9 of 14 Old 04-11-2009, 12:58 PM
the 5.5mV you are reading is nothing, meaning without a doubt you have a faulty horn switch... i doubt it's to hard to fix though, strip it down and clean it up and all should be well
i fitted a nautilus horn other day, you have to use a relay as the stock horn is only a few amps and the nautilus is something like 18amps @ 12v, so without a relay you will cook your horn button
i pulled out stock horn and ran wires from that to the relay coil. then the switched contacts on relay powered up horn with a direct feed from battery via a 20a inline fuse.
nautilus should come with a relay, well mine did :)
Fluke is offline
post #10 of 14 Old 04-11-2009, 02:18 PM Thread Starter
russell's Avatar
yeah my nautilus came with a relay.
i'm just going to re-run and re-solder the cables for the horn with 14g wire. hopefully that will do it.
russell is offline
Horn Upgrade Wheeltrax The ZX-10R 9 01-18-2009 02:52 PM
Horn Doesn't Work JP636 Performance and Tech 4 11-25-2008 06:10 PM
Car horn mod. LOUDER THAN MY CAR 06Neenja Performance and Tech 20 05-23-2008 09:19 PM
Horn upgrade Bradlee_T Pictures and Videos 8 10-26-2007 07:17 AM
Now I've got the horn.... Goatozaki Pictures and Videos 15 09-17-2004 02:26 AM
