My 08 10R can't get over 140HP - Kawasaki ZX-10R.net
post #1 of 24 Old 07-26-2010, 09:36 PM Thread Starter
pallykuo's Avatar
Send a message via MSN to pallykuo
I got Akrapovic slip-on and mid link pipe, and mileage is about 20000 km.
In dyno testing, no matter the O2 is installed or removed, no matter PC5 is set or not, the max HP just can't get over 140HP.
Eng is in good situation.
Is it possible that ECU restrict the ignition timing ? or KIMS panic?
pallykuo is offline
post #2 of 24 Old 07-26-2010, 09:38 PM
ronnulph's Avatar
Send a message via Yahoo to ronnulph
I believe the KIMS is not in effect at WOT. What are other bikes getting on that dyno?
08 ZX10
ronnulph is offline
post #3 of 24 Old 07-26-2010, 09:41 PM Thread Starter
pallykuo's Avatar
another 08 10R, stock setting, about 152HP
pallykuo is offline
post #4 of 24 Old 07-26-2010, 09:44 PM
bluedevil's Avatar
Yeah...that's what matters....I met a Rider on the street near my house a few months back.....we talked and said he hit 140 + on a Dyno(3rd Gen)...new bike too.....did I think I had more with my Dyno #s when I first bought my bike(156HP) on a different Dyno different year/Day etc.? :headshake
bluedevil is offline
post #5 of 24 Old 07-26-2010, 09:45 PM
ronnulph's Avatar
I would check all simple stuff first. Plugs, air filter, chassis ground, etc,,,, Maybe the clutch is slipping a little and the engine is putting out the right power.
08 ZX10
ronnulph is offline
post #6 of 24 Old 07-26-2010, 09:47 PM
ronnulph's Avatar
I have also heard tire pressure effects the dyno but I don't know how true that is.
08 ZX10
ronnulph is offline
post #7 of 24 Old 07-26-2010, 09:54 PM Thread Starter
pallykuo's Avatar
In fact, before putting my 10R on dyno, K&N air filter is clean, plugs changed.
th reduction ratio is changed from 41/17 to 42/16 for sunday track purpose.
The interesting thing is , NGK CR9EIA-9 and CR9EIX seems no difference on dyno. It seems something sealed my 10's power....
pallykuo is offline
post #8 of 24 Old 07-26-2010, 09:59 PM
ronnulph's Avatar
how did your old plugs look? When I was running the BMC race filter my ride was running lean. My bike seems to run a little stronger with the stock air filter. Did you gut the cats out of the header pipe? If you are running the autotune + PCV with cats, you may be running way too rich.
08 ZX10
ronnulph is offline
post #9 of 24 Old 07-26-2010, 10:00 PM
nickalltogether's Avatar
It does (on car dynos at least) but it isn't a huge difference.
2012 Kawasaki ZX-6R-Black
Clear Alternatives Tail Light
2005 Honda F4i-Red
Commuter stuff
2003 Yamaha Zuma-Fairy Silver
TPT 70cc Kit, Leo Vince ZX Exhaust, Malossi Delta Clutch, Scott's Damper Sticker
nickalltogether is offline
post #10 of 24 Old 07-26-2010, 10:50 PM Thread Starter
pallykuo's Avatar
the old plugs looks great.
pallykuo is offline
