Muzzy (Hyperpro) damper install question - Kawasaki ZX-10R.net
post #1 of 4 Old 07-03-2005, 12:25 AM Thread Starter
Administrator
YSR50's Avatar
Images: 32
I have a question about installing the Muzzy (Hyperpro) damper. The assembly notes are not that clear to me. Just for the record, I'm not mechanically inclined at all, but this seams like it should be easy enough if I just get a few things clear.
Below I've laid out the parts like the instructions say, I think. I just want to make sure before I start using locktight on everything . My main questions are:
  1. are the studs correct? long threads down, short threads up? (I assume so) I think Hyperpro uses allen bolts instead of nuts and bolts.
  2. does the short button head bolt go to the clamp and the long one go to the damper rod or vise versa?
  3. are the O-rings/washers in the correct places???
TIA
"Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
--Dr. Seuss
YSR50 is offline
post #2 of 4 Old 07-03-2005, 03:20 AM
I just installed mine. I put the o-rings under the washers,just seemed what the instructions implied was right.
Airborne... All The Way!!!
Floyd is offline
post #3 of 4 Old 07-03-2005, 11:51 PM
Send a message via AIM to gladding24
A ZX-10, Zx-9, YFSR200, YSRR125, and a YSR50 and you're Still Maintainance impaired??!!???!???!
Stop Whining!!!
It ain't easy being Green ~ Kermit The Frog
Arguing on the internet is like running in the Special Olympics.....Even if you win...you are still retarded
CaliSuperbikes- "these are high strung machines, and we're giving them a constant dose of Red Bull"
gladding24 is offline
post #4 of 4 Old 07-04-2005, 01:05 AM Thread Starter
Administrator
YSR50's Avatar
Images: 32
I can pull the motors and change pistons and rings on the 3 smaller bikes, no problem. The instructions on this damper just kind of suck. The picture that they include is a smaller one of what's on their site.
and I quote:
"There are two O-rings supplied. They are to be positioned under the heads of the two button-head allen bolts that secure the rod ends to the mount brackets. They will spread over the ball ends as the bolts are tightened. Their function is to prevent "flopping" of the damper assembly and maintain ball end alignment."
--Dr. Seuss
YSR50 is offline
Muzzy steering damper gogreen Vendors deals 34 06-09-2005 08:26 AM
steering damper question Stud_wit_style The ZX-10R 23 04-29-2005 02:07 PM
Installing Hyperpro damper?? STREETFIGHTER50 Performance and Tech 9 02-11-2005 03:43 PM
Muzzy Exhaust Question fast1 The ZX-10R 6 01-18-2005 07:42 AM
long story of my hyperpro active damper latdrop The ZX-10R 14 10-29-2004 10:41 AM
