Muzzy aluminum fan on the 10R? - Kawasaki ZX-10R.net
post #1 of 21 Old 08-13-2007, 05:01 PM Thread Starter
Send a message via Yahoo to crazyhawk99
Has anyone tried to Muzzy aluminum fan to replace the stock one on their 10R? If so, how much of a pain was it to install and did you notice the bike running any cooler.
I just ordered one and will post results when I get around to putting it on. Don't hold your breath though... I am way backed up on projects.
"There are days when it takes all you've got just to keep up with losers."
Current Fleet:
09 BMW R1200GS
04 ZX10R
02 HD Heritage Springer
03 SV650
88 HD Sportster
crazyhawk99 is offline
post #2 of 21 Old 08-14-2007, 12:32 PM
Gang Green's Avatar
Not even sure if Muzzy make an aluminum fan for current ZX10R models.
I does make them for the older 88-90 models. Those models were prone to melting the fan because the fan was so close to the header pipe.
Rubber Side Down!!!
"Read The Signs"
God gave Rock'N Rolll to ya, and Kawasaki too!
Gang Green is offline
post #3 of 21 Old 08-14-2007, 12:40 PM
sweetride10r's Avatar
I had one on mime the stock fan worked better
bike is down for not but not out
turbo project is a slow go no money
Need some work done
call 586-214-2414
sweetride10r is offline
post #4 of 21 Old 08-14-2007, 03:46 PM
Papabear's Avatar
I had one on my zx-7 and one of the blade broke off and hit the rad fins. I was lucky it didn't puncture it.:headshake I went back to stock.
Papabear is offline
post #5 of 21 Old 08-15-2007, 07:34 AM
themightymezzo's Avatar
Looking in the service manual last night because I'm considering a full exhaust and wanted to see what I had to do...of course take the radiator off and was looking at the...it seems to get the fan off you have to take the radiator off.
I could be wrong though.
If you do it seems like a lot of work just to install a fan that might not work the best from what people are saying.
"You can't trust anyone, not even your own asshole; sometimes you think you're gonna fart and you sh*t."
themightymezzo is offline
post #6 of 21 Old 08-15-2007, 08:36 AM
greg 0410r/6rr's Avatar
I replaced everyone of my stock fans w/ a Muzzys except my '06 ZX-10R. The one on my '96 ZX-7R stripped. Ever since then I replaced them. The have an extra blade and cools the engine faster. Hence, less battery drain.
greg 0410r/6rr is offline
post #7 of 21 Old 08-15-2007, 06:04 PM
bugman53's Avatar
They will push more air than stock. They help alittle for stop and go riding but not really a needed mod. Unless you are a parking lot cruser.
High Velocity Cycles 2005 Ti ZX10R
Greeensboro NC
bugman53 is offline
post #8 of 21 Old 08-15-2007, 09:19 PM
bkkninja's Avatar
Not a mod I think of. Racers sometimes remove the fan completely to save weight.
bkkninja is offline
post #9 of 21 Old 08-16-2007, 03:03 AM Thread Starter
Thanks for the input. I am definititely not a parking lot cruiser, but sometimes get caught in a stau (traffic jam) on the autobahn and I figured the fan would help some.
Current Fleet:
09 BMW R1200GS
04 ZX10R
03 SV650
88 HD Sportster
post #10 of 21 Old 08-16-2007, 03:05 AM Thread Starter
Thanks for your input. Pretty much goes along with what I was thinking. Cooler is better, right? :)
Current Fleet:
09 BMW R1200GS
04 ZX10R
03 SV650
88 HD Sportster
5 blade aluminum fan blackisfaster Performance and Tech 7 10-09-2006 10:36 AM
Aluminum Fan Blade colinmitchell111 The ZX-10R 5 08-16-2006 03:34 PM
604 cu in Donovan Aluminum Block BIKEMIKE Pictures and Videos 2 09-10-2005 10:31 AM
FS: Jardine Aluminum Bolt On junjun Parts, Gear and Accessories 0 08-14-2004 07:42 PM
Installed Muzzy aluminum cooling fan. ZX10 Guy The ZX-10R 18 08-13-2004 05:55 PM
