Gen 4: 2011-2015 motor problem/oil/coolant leak already - Kawasaki ZX-10R.net
post #1 of 8 Old 05-16-2012, 12:25 PM Thread Starter
Gen 4 zx10 with 5k miles already have a coolant leak. There is oil coming from coolant reservoir overflow WTF is going on, anyone else having this problem or heard of it???
GRKZX10R is offline
post #2 of 8 Old 05-16-2012, 01:07 PM
SkyDork's Avatar
What exactly do you mean by this? The overflow is designed to drain out onto the ground if overfilled due to expansion in the motor. It's coolant though, not oil. Don't know what you're trying to describe, but at first glance, I don't think you have any issues if it's just a bit of coolant pissing out.
#WordCrimes
SkyDork is offline
post #3 of 8 Old 05-16-2012, 04:27 PM Thread Starter
Thanks for the reply Sky.
First, let me state that bike is flashed by Dynotronics, has K&N, Hotbodies exhaust and custom link pipe.
Do understand the purpose of overflow but it should only be coolant as fas as I know but I'm no expert. The problem here is that leak contains oil and as you can see in the pic, looking under the radiator cap you can also see oil presence. The bike ran strong last time it ran but after the coolant/oil mix under it it has not been ridden.
Head gasket.? Any other possibilites that could get oil in coolant.?
Thanks.
GRKZX10R is offline
post #4 of 8 Old 05-16-2012, 04:42 PM
SkyDork's Avatar
Hmmmm....yeah, that doesn't look good. Gonna take some further diagnosis and elimination at this point. It's not likely a head gasket. The oil and water wouldn't mix there and you'd be seeing a lot of smoke out the exhaust from that happening. I'd be looking in the water pump area. Bad oil seal?
If you intend to diagnose it yourself, I would first get my self a pressure tester for the cooling system. This is a hand pump that connects over the radiator cap. You pressurize the system and then monitor to see if the pressure stays or leaks down. If it stays, everything is good. If it leaks down, there's an issue and then you can start checking for where the leak may be. It's gonna be a PITA, but since it's new hopefully you can take it back to the dealer and get it looked at under warranty. At first glance I don't think it's a major issue like a head gasket. But definitely don't want it to turn into a major issue if you've got coolant in your crankcase! That would be bad, bad, bad!!!
#WordCrimes
SkyDork is offline
post #5 of 8 Old 05-16-2012, 11:43 PM
teedub21's Avatar
How does the oil look? Milky? If so, then head gasket. Do these bikes have an oil cooler and if so, is it part of the radiator? Could there be something going on there?
teedub21 is offline
post #6 of 8 Old 05-17-2012, 05:51 AM
Gen2 Ripper
neverendingmods's Avatar
Oil cooler is not part of radiator, but yes it has oil cooler.
Start the bike with radiator cap off and see if there is air bubbles present or not.
I would be putting stock parts back on and taking it to dealer if it was my NEW bike.
neverendingmods is offline
post #7 of 8 Old 05-28-2012, 11:26 PM Thread Starter
Fyi bad oil cooler coverd by warranty
GRKZX10R is offline
post #8 of 8 Old 05-29-2012, 09:08 PM
Gen2 Ripper
Good to hear they covered it. That sucks. Did they fully flush it. And make sure it is documented that the oil cooler failed and mixed oil/coolant.
coolant leak edouble Performance and Tech 3 05-03-2010 04:50 AM
Coolant leak? Sik10r Performance and Tech 14 06-29-2009 07:11 PM
Coolant leak Help??? kneedragger Performance and Tech 37 10-20-2008 03:46 AM
Coolant Leak 1kdoubler The ZX-10R 16 11-08-2005 07:03 PM
Coolant leak??? BlackNinja The ZX-10R 19 05-16-2004 09:44 PM
