Motion Pro SyncPro Carb Tuner - Kawasaki ZX-10R.net
post #1 of 16 Old 04-11-2009, 07:41 PM Thread Starter
bluedevil's Avatar
Any one use this before?
I bought one today can't wait to see how it works:
https://www.phatperformanceparts.com...Code=3804-0003
bloo
bluedevil is offline
post #2 of 16 Old 04-11-2009, 07:54 PM
FEELING LUCKY, PUNK ?
Lucky10R's Avatar
Images: 19
no instructions whatsoever ?
Lucky10R is offline
post #3 of 16 Old 04-11-2009, 07:57 PM
Lucky10R's Avatar
Images: 19
shoulda bought carbtune :)
Lucky10R is offline
post #4 of 16 Old 04-11-2009, 07:57 PM Thread Starter
bluedevil's Avatar
Why do you need Instructions? It's suppose to be just like any other sync but with better functions and safety.
post #5 of 16 Old 04-11-2009, 09:01 PM
ducatiryder89's Avatar
Images: 21
Well it works like really any other sync tool. I liked the Mercury ones better but I can't get those anymore so I'm kinda stuck with those. They come with instructions on how to put the check valves and hoses and they are exactly like the old mercury sync tools in use.
ducatiryder89 is offline
post #6 of 16 Old 04-11-2009, 09:10 PM Thread Starter
bluedevil's Avatar
Thanks,
I thought about putting my mercury in from my old one but realized the tubes may be to short and will over flow.
So why do you like the mercury ones better over this one? Does the fluid run to much to make it hard to read or something? ....as that is my main concern.
bloo
post #7 of 16 Old 04-11-2009, 10:23 PM
SpazOnaZX's Avatar
I order/used that one not too long ago. It's a good tool, supplied with all the instructions you need. My only bitch about it is that they tell you to "calibrate" the tool every time you use it.... but it isn't hard to do that at all with the way the tool is set up.
As far as function it works just like an old mercury tool. The contrast is nice and high, and the anti-flutter check valves work as advertised. I used to have the old mercury Motion Pro tool, and this one is just as good (and less fragile!)
SpazOnaZX is offline
post #8 of 16 Old 04-11-2009, 10:31 PM Thread Starter
bluedevil's Avatar
why would you need to calibrate it?...all cells are seperate so I suspect because of the fluids not being the same like mercury is?
bloo
post #9 of 16 Old 04-12-2009, 11:39 AM
SpazOnaZX's Avatar
...it has something to do with the gravity of the fluid itself, if I'm not mistaken. If I read the instructions correctly, the "output" accuracy of the guage will be affected by different/higher levels of vacuum,so they ask you to calibrate it to each new vacuum source. I didn't really pay much attention to the explanation as to why when I did it... I just calibrated the thing and marched on. :) It's easy enough to do. The tool does not give you any sort of in/Hg reading...... it's just a comparative vacuum tool. :)
post #10 of 16 Old 04-12-2009, 05:42 PM Thread Starter
bluedevil's Avatar
Thanks for the reply. The way I am reading the Calibration is you need to calibrate all tubes based on 1 Vacuum, so you hook all 4 tubes via the 4 way splitter to 1 vacuum off the throttle body and adjust the screws on top of the manifold housing to make them all even in fluid level. Then at that point you know any variance in vacuum will show TRUE when they are all hooked up separately.
bloo
Carb diaphram afskypilot Performance and Tech 5 11-28-2007 03:26 AM
Carb rebuild afskypilot Performance and Tech 2 11-20-2007 04:54 PM
Anyone ever use a Motion Pro on ATV? Dan The Out House 3 11-16-2007 12:27 PM
wtt: carb yosh trs sturgill_13 Parts, Gear and Accessories 3 04-02-2007 04:09 PM
Tuner bike vs. Tuner car 1killer1liter The ZX-10R 8 10-11-2005 10:44 PM
