More torque - Kawasaki ZX-10R.net
 3Likes
  • 3 Post By SpazOnaZX
post #1 of 7 Old 02-22-2019, 08:02 AM Thread Starter
More torque
Can you get more torque without losing horsepower
Joejess is offline
post #2 of 7 Old 02-22-2019, 08:49 AM
ddipaola's Avatar
Change your sprockets.
When in doubt... send it!
ddipaola is online now
post #3 of 7 Old 02-22-2019, 11:14 AM
GreenWeenie's Avatar
Changing your gearing will make it FEEL like you have more torque, but doesn't change the actual rating.
Power curve is always a trade off. For more torque, you need slower air movement which generally means smaller pipes and fuel runners, which reduce HP. Or you can add displacement. A big bore kit gets both.
The later gen ZXs are notorious for weak mid range torque, in exchange for peak power.
18 Ninja 400R
17 ZX10RR
16 S1000R
14 BMW S1000RR
1996 ZX7R
CaliTrackDays A group Marshall
GreenWeenie is offline
post #4 of 7 Old 02-22-2019, 11:43 AM
ddipaola's Avatar
Shhhhhhhhhh, we can't get too technical on this guy
post #5 of 7 Old 02-22-2019, 02:32 PM
Porschenut's Avatar
A good ECU flash should give you both torque and horsepower over stock.
2013 ABS, Bridgestone T30 Evo, Woolich, Danmoto shorty & link, Rifleman's 1/5th turn, K&N, GP shift, Gen5 shock/links/dogbone, geared (-1/+0), Shorai, EBC HH, AllBallz roller steering, Ohlins NIX30, Lightech adjusters. Bestem carbon. 50,000km+ and good so far.
Porschenut is offline
post #6 of 7 Old 02-22-2019, 03:03 PM
SpazOnaZX's Avatar
Some days I just have to say something.
More horsepower IS more torque, and vice versa. When an engine combination is close to it's design limit, you can move your torque peak around with cam/exhaust/intake timing. WHERE do you want to make more torque?
Second, gearing shorter DOES increase actual torque applied to the tire, the trade off being that it removes some potential top speed. It's WHY we have transmissions in the first place, and it's also why the lower gears accelerate much more quickly than the higher gears (more effective torque).
Want more torque everywhere? Gearing. Want more torque AND top speed? increase the design capability of the system. Easiest ways: nitrous, turbo, big-bore, more stroke, better fuels, higher static compression.... all assuming you re-tune to suit.
Want to move your torque around? Play around with cams and cam timing.... may even find some 'free' power in there if you do it right.
CanyonCarver, gaz and wheelz96 like this.
SpazOnaZX is offline
post #7 of 7 Old 03-04-2019, 09:45 AM
With the later model zx10 you can gain big torque by swapping the head pipe merge. Both Akro and Graves do this.
As for how the torque is applied to the rear wheel by sprocket size/gear ratio. It is possible to gain leverage on the rear wheel by installing a large rear sprocket however just changing the final drive ratio effects the ratio of time/speed in which peak torque is available.
I personally like tall gearing so I can spend more time at peak torque without shifting
bbsteinnewyork is offline
Need More Torque?? kawboy69 Performance and Tech 18 01-01-2013 12:21 AM
made a few more passes tonight and getting a little more satisfied with the bike cookmaster30 Strip 7 08-27-2011 08:08 PM
AMA Getting more and more like Nascar Vio Race and Stunt 28 03-05-2009 10:26 AM
