moose easy pull clutch - Kawasaki ZX-10R.net
post #1 of 10 Old 05-26-2007, 07:47 PM Thread Starter
rojapar's Avatar
anyone stuck one of these bitches on their 10r yet? if so, how did it work out?
rob
If it smells like cologne, leave it alone.
rojapar is offline
post #2 of 10 Old 05-26-2007, 08:26 PM
rocketracermike's Avatar
is it some type of new lever. havn't heard of it before.
rocketracermike is offline
post #3 of 10 Old 05-26-2007, 08:30 PM
use this one!!!!!
ninja2k5 is offline
post #4 of 10 Old 05-26-2007, 08:33 PM Thread Starter
rojapar's Avatar
it is mainly used on dirt bikes...it hooks btw your clutch lever and cable...it changes the leverage ratio and makes the clutch lever easier to pull.
dont know of anyone using them on street bikes. i saw one at the dirt bike shop yesterday and it looked interesting.
http://www.motorcycle-superstore.com...656&Division=6
rob
rojapar is offline
post #5 of 10 Old 05-26-2007, 08:35 PM Thread Starter
rojapar's Avatar
Originally Posted by ninja2k5 View Post
use this one!!!!!
i dont want to get to freakish looking
rob
rojapar is offline
post #6 of 10 Old 05-26-2007, 08:36 PM
first time i seen them. my clutch isn't hard to pull in. it would be nice to hyd clutch.
post #7 of 10 Old 05-26-2007, 08:40 PM Thread Starter
rojapar's Avatar
mine isnt hard either, but i was thinking it would make it easy to single finger it so i could keep the others on the bar...and was thinking it might make disengagement a fraction faster for speed shifting.
never tried one though, so i really dont know how they would work out.
rob
rojapar is offline
post #8 of 10 Old 05-28-2007, 04:44 AM
if it makes it easier to pull the clutch in by changing the ratio, it will take a longer pull to accomplish the same amount of work, so any advantage you gain by having less resistance will be offset. Once you factor in friction and resistance from the unit, you will actually end up losing.
vorderma is offline
post #9 of 10 Old 05-29-2007, 05:41 AM
kingoose's Avatar
Send a message via MSN to kingoose
I've seen this before on old spanish bikes which clutches were hard to push. It's a simple lever mechanism inside, and can be adapted to any bike...
You can also make your clutch "softer" enlarging the clutch lever on the clutch cover, I've seen it and it really works!
www.gassattack.com
kingoose is offline
post #10 of 10 Old 05-29-2007, 10:03 PM
The easy pull is an old four stroke dirt bike trick when clutch material was junk and heavy spring pressure was needed. I installed one on my wife's gixxer (sorry for the horrible language) cuz she's a girl and is weak. I had to make a custom cable for it because they are designed to be mounted at the perch and on a sportbike there isn't enough room, plus it's ugly. Any way it does make the pull lighter, but you need more travel at the lever for full engagement/disengagement of the clutch. ie. if you don't pull the lever to the bar you'll be shifting under drag.
matt is offline
Clutch pull too hard on '05 ZX-10 IcePick06 Performance and Tech 17 05-01-2006 08:38 AM
ping moose DB The ZX-10R 14 06-15-2004 01:31 PM
Fender Eliminator (Moose) Ninja Dude The ZX-10R 3 05-28-2004 12:16 PM
Hey Moose? CDRacingZX6R The ZX-10R 13 05-16-2004 09:30 PM
