Modifications for full exhaust system - Kawasaki ZX-10R.net
post #1 of 15 Old 12-10-2005, 04:14 PM Thread Starter
Please confirm what kind of modifications you have done when installing full race exhaust system ?
* exup cables removed ? How about the servo motor ?
* any factory modification kit for removing the air circulation from the exhaust system and engine head ??? What you have done ???
thanks....
lespaul66 is offline
post #2 of 15 Old 12-10-2005, 04:58 PM
Andy's Avatar
Images: 25
moved
Andy is offline
post #3 of 15 Old 12-10-2005, 07:59 PM
phastone's Avatar
thanks....
yes. yes. and yes. most, if not all, full systems require removal of the cables and the servo itself and the KLEEN system can be taken care of with products from here. http://www.ivansperformanceproducts.com/other.htm
phastone is offline
post #4 of 15 Old 12-11-2005, 04:22 AM Thread Starter
thanks
thanks
Ivans kit looks professional but I am still a little bit worried - there is a screw thread tool in a kit...I suppose it is meant for engine head air duct openings...But but and but !!!
How you can be sure that aluminium chips are not going to wrong direction and to engine cylinder !!! Seems to be a little bit risky way to block the holes (make threats to holes and then instal the plug bolts)...
How many of you have just plugged the original hoses in this case ??? And how mony of you have let the servo motor in its place and just removed the wires - no error code if the servo motor is there ???
post #5 of 15 Old 12-11-2005, 01:18 PM
phastone's Avatar
lespaul, I think you were looking at the wrong kit. The one for the 10R doesn't invlove tapping any holes. The 10R kit consists of the two block-off plates, 4 bolts, and a cap to plug the place on the airbox where the KLEEN system's hose hooked to it. It's and easy mod except getting to the front bolts for the plates is a bit of a pain.
You can leave the servo motor in the bike, no big deal. Just unhook the cables from the motor. As long as the motor is connected to the ecu, you won't get any codes.
phastone is offline
post #6 of 15 Old 12-11-2005, 02:22 PM Thread Starter
thanks
phastone...thanks for your information...indeed zx10r needs only those block plates...and because the servo motor is so small and light, I will keep it...just going to take the cables off...
thanks once more...
post #7 of 15 Old 12-11-2005, 02:29 PM
MIA Post Whore
miykl's Avatar
The exhuast servo gots to go!! Gives you a weight reduction eqivalent of an extra four tacos a week. Trust me. I know my tacos.
2011 Ninja 1K street
2004 636 track
miykl is offline
post #8 of 15 Old 12-11-2005, 02:52 PM
rocketracermike's Avatar
Listen to the man. Every taco bell in texas has a vip parking space for him.
rocketracermike is offline
post #9 of 15 Old 12-11-2005, 02:58 PM Thread Starter
servo weight
Servo is very light like tobacco box...no problem to keep it...
post #10 of 15 Old 12-11-2005, 03:05 PM
Big Daddy's Avatar
Images: 38
ya sure thats not the well established 'handicapped' spot??
Big Daddy is offline
Muzzy Sidewinder Exhaust System Ryan Schnitz Vendors deals 10 01-12-2006 02:06 PM
exhaust system biker_larry1000 Performance and Tech 3 06-05-2005 01:08 PM
How do you rate is Exhaust system? vane The ZX-10R 12 04-14-2005 12:30 AM
Brock Performance Exhaust System hillcountry10r The ZX-10R 5 01-25-2005 09:06 PM
Muzzy Exhaust System Blowout!!! Ryan Schnitz Vendors deals 28 01-11-2005 03:32 PM
