mixture - Kawasaki ZX-10R.net
post #1 of 7 Old 02-08-2010, 11:13 PM Thread Starter
m0t0 GP's Avatar
mixture
have an 08 mgp slip on and an akra midpipe. i put the PCIII on and i used to be able to hit atleast 100 in first. now only 80. its winter in here in NJ does the cold weather effect it?
m0t0 GP is offline
post #2 of 7 Old 02-08-2010, 11:23 PM
Sebastian1000's Avatar
Did you also do a sprocket change while you were at it?
1976 250 Elsinore Sold
1997 600R Sold
1976 KZ 900 Sold
2003 1500 Meanstreak Sold
2006 DL 650 Sold
2002 919 Hornet Sold
2004 ZX-10R
Sebastian1000 is offline
post #3 of 7 Old 02-09-2010, 12:06 AM Thread Starter
m0t0 GP's Avatar
those are the only mods i have. hotbodies mgp slip on, akra mid pipe and the PCIII. i just was curious as to whether it was the weather temp or the map being
m0t0 GP is offline
post #4 of 7 Old 02-09-2010, 08:44 AM
Speed Freak
garth285's Avatar
no it shouldn't make a difference, make sure your going to the same RPM's though as in hitting the rev limiter :-)
garth285 is offline
post #5 of 7 Old 02-09-2010, 08:59 AM
Bhawk's Avatar
Did you buy the PCIII used? If so, there might be a crap map in it. Did you have the bike tuned? Did you get a new back tire?
Squids should be outlawed!!
Bhawk is offline
post #6 of 7 Old 02-09-2010, 09:05 AM
tagger's Avatar
I agree with the others... without a sprocket or tire change, you shouldn't have any trouble hitting 100 in first. Are there any side effects - bogging, lack of power, etc?
tagger is offline
post #7 of 7 Old 02-09-2010, 12:10 PM
beenthere's Avatar
I'm going to assume before the PC is when you hit 100 and now after its install you lost performance? Maybe your install wasn't good, ie bad connections, power, ground, and any hoses or wires you may have had to deal with for the install. I know 1st gen 10R's ram air tubes have to be carefully re-installed in the frame ports so as not to be obstructed. Not seating the airbox on the injector velocity stacks can sometimes happen if your not careful. The map or lack of correct mapping could have hurt power. Nice vintage pic for the avatar
beenthere is offline
Question about water/redline mixture for the track PumpinIron General Motorcycle Discussions 6 11-02-2008 03:21 PM
Adjusting fuel mixture. Help me out guys... BenRyDn Performance and Tech 6 02-14-2005 10:14 AM
