Gen 1: 2004-2005 Misfiring please help - Kawasaki ZX-10R.net
post #1 of 2 Old 07-21-2012, 09:00 AM Thread Starter
It feels like I have a misfire and I tested the temp of the exhaust so I could find what one was misfiring and cylender 4 was about 20-40 degrees colder I changed the spark plug and the pack but still runs 20-40 degrees cooler . . . Anyone have any idea what it could be ?
j.waring is offline
post #2 of 2 Old 07-21-2012, 12:29 PM
Swap the fuel injector with another cylinder's injector, then see if the temp difference changes to the other test cylinder.
Check the lobes on the intake and exhaust side of the cam shafts on that cylinder, make sure they haven't been ground down.
If this problem only happens on idle, pull the air bypass valve on the throttle body for that cylinder and make sure its not clogged.
Check for carbon buildup, use a camera from Lows (you can return it after using it). Perform a compression test and see if that cylinder is significantly different from the rest. A leak down test would also be useful if you have the equipment.
2006 ZX-10R :: Just a shade tree mechanic keeping a 75,000 mile beast alive.
antaren is offline
Gen 2: Misfiring with new plugs! BigCat10R Performance and Tech 26 05-02-2012 12:33 AM
Gen 2: Misfiring problem OPP41 Performance and Tech 10 06-29-2011 06:05 PM
misfiring under load!!! Any idea's speedtechnz Performance and Tech 17 08-01-2007 10:01 AM
