Micron Serpent Exhaust - Kawasaki ZX-10R.net
post #1 of 15 Old 01-31-2010, 02:48 PM Thread Starter
Are any of you using Micron's Serpent exhaust system?
If so, can you assist me with some information?
stock engine (exhaust/usb)
-hp gain
-tq gain
modified engine (head,cams, higher compression)
-hp gain over stock
tq gain over stock
I am thinking of switching from my Tsukigi exahust to a Micron Serpent. I am trying to determine if it's worth the money.
Thanks
JTR Inc
2012 Zx14R-Blk: BSTs/Alumi-Pro arm/Brock Short Smeg/ECU Unleased
2012 azx14R-Smurf Blu: PMs/ Evil- chrome moly arm/Brock Short Smeg/ECU Unleased
2011 Zx10R-Blk: BSTs/Evil-chrome moly arm/Brock Short Smeg/ECU Unleashed
justoyz2 is offline
post #2 of 15 Old 01-31-2010, 03:29 PM
My understanding is Micron went out of business years ago. What is still being sold is left over stock. I looked at them about a year ago because some are being dumped at super cheap prices, but decided against them.
I don't think Micron was ever known for big hp increases.
TN10R is offline
post #3 of 15 Old 01-31-2010, 03:39 PM
ZX-10R enthusiast
dudewhrsmybike's Avatar
FYI, you can get a serpent system (minus Micron can) for $199.
If that's not a good deal, I don't know what is.
I haven't got mine on and tuned yet, but when I do, I will share what info I have.
Strictly for my Ninjas
https://www.instagram.com/mistr.123/
Current Ride: 2016 ZX-10R ABS (under construction)
Former Ride: 2011 ZX-10R ABS
17/41, Woolich Racing Tuned ECU and QS, Rifleman's 1/5th throttle insert, CL XBK5 pads, Yosh case sliders, Mivv Carbon w/ Ti Akra link
dudewhrsmybike is offline
post #4 of 15 Old 01-31-2010, 03:43 PM
beenthere's Avatar
Used a Micron Serpent full system on a 2001 Hondoodle 929 and it performed very good with a downloaded Micron map at Power Commander.com. Smooth low end, crisp midrange, and a willingness to make hp in the upper rpm range.
beenthere is offline
post #5 of 15 Old 01-31-2010, 07:44 PM
sweetride10r's Avatar
what are you doing with the bike drag, all motor or spray?
bike is down for not but not out
turbo project is a slow go no money
Need some work done
call 586-214-2414
sweetride10r is offline
post #6 of 15 Old 02-01-2010, 12:03 PM
vataren's Avatar
i installed one a few months ago and i tell you go for it...
with KN air filter and a power commander i had a 13 hp gain...
with a map from dynojet website
zx10r 04, micron serpent full race titanium system, KN air filter, power commander, matris steering damper,goodridge brake lines, brembo brake master cylinder.
vataren is offline
post #7 of 15 Old 02-01-2010, 12:30 PM Thread Starter
serpent exhaust
I am a drag racer...
potential mods are:
-head porting
-Kawi race cam(intake) or set of webcams
-existing exhaust is a Tsukugi full system(looking to swap with the serpent)
I just wanted to know if the exhaust is worth swapping out.
The asking price is 310, but I saw on the forum they are running around 200 (where can I get a new one for 200.00)
justoyz2 is offline
post #8 of 15 Old 02-01-2010, 12:41 PM
very much worth it, every person I know has increased hp
kaoss_11 is offline
post #9 of 15 Old 02-01-2010, 03:27 PM
i would stick with what u got put that money into the motor
Need some work done
call 586-214-2414
post #10 of 15 Old 02-01-2010, 06:45 PM
dirt ninja's Avatar
Images: 9
Im sure the tsukigi system is better quality than the micron. I used to have the tsukigi and i've seen the micron system on your first gen. Use the money for your motor as others have stated.
Marchesini Magnesiums,Nassert beet,kawi cam,.45 headgasket,DJ PC/Ig.M/QS,velocity stacks,bmc race,gipro,sato rearsets,helibars,throttlemeisters,pazzo shorties,speedohealer,520 renthal sprockets,penske 8393 double clicker,traxxion dynamic springs,scotts stabilizer,lsl frame sliders,cox radiator guard,powerbronze hugger,puig DB,solo seat cover,Valentine1,dual low beam projectors,55w.hids, brembo superbike rotors,Goodridge superbike lines,nissin calipers and rizoma mirrors,mda123 battery.
dirt ninja is offline
Just bought a MICRON SERPENT FULL SYSTEM vataren The ZX-10R 25 10-04-2009 11:46 AM
anyone running a MICRON Serpent full system on a 06 ? Speedyj The ZX-10R 4 02-13-2007 05:07 AM
Micron serpent header advice SaffieD Performance and Tech 16 11-20-2006 06:44 PM
micron serpent system for 04/05 10 TR-10 The ZX-10R 2 10-18-2006 04:04 PM
micron serpent pipe steve p The ZX-10R 9 07-14-2004 05:33 PM
