Metal flakes on my chain - Kawasaki ZX-10R.net
post #1 of 26 Old 05-27-2012, 05:24 PM Thread Starter
Austinjval's Avatar
So I was gonna clean and lube my chain today when I noticed metal flakes on the chain, chain guard and under the front sprocket cover. I bought the bike about 3 months ago and I believe the chain and sprockets were pretty much new. I've since put about 2,000 miles on the bike. Could it just be from me neglecting to keep the chain pristinely clean or is it a technical problem? Chain slack is correct and the rear is aligned properly. Sprockets don't appear to be wearing abnormally.
ID:	161842   Click image for larger version
ID:	161843   Click image for larger version
Austinjval is offline
post #2 of 26 Old 05-27-2012, 05:32 PM
Quick10's Avatar
wow that looks pretty nasty...You need to pull the sprocket cover and do a thorough cleaning to see where the issues are coming from.
Quick10 is offline
post #3 of 26 Old 05-27-2012, 06:00 PM
All show and all go 10r
JLG0987's Avatar
wow you gotta clean and lube your chain dude. The metal is probably from the sprockets.
JLG0987 is offline
post #4 of 26 Old 05-27-2012, 06:24 PM
dude, look at the first pic! the aluminum sprocket teeth are mushed!!!
mityaz is offline
post #5 of 26 Old 05-27-2012, 08:58 PM
Post Whore
-Op-'s Avatar
thats what I was thinking. it looks like your sprockets are being shaved and thats whats going every. I would get new ones man.
-Op- is offline
post #6 of 26 Old 05-27-2012, 09:46 PM
JLG0987's Avatar
You should also get a new chain if that's the damage being done to the sprockets the chain wouldn't be doing much better.
JLG0987 is offline
post #7 of 26 Old 05-27-2012, 10:22 PM
barnes's Avatar
Send a message via MSN to barnes
Have u checked the inside of the swingarm? Even the end of the thread looks worn?
barnes is offline
post #8 of 26 Old 05-28-2012, 01:31 AM
Gen2 Ripper
neverendingmods's Avatar
Look at the cush drive and make sure there isn't a gap. And make sure the wheel spacer is not damaged.
neverendingmods is offline
post #9 of 26 Old 05-28-2012, 02:07 AM
badexample's Avatar
Replace both sprocket and chain asap.
badexample is offline
post #10 of 26 Old 05-28-2012, 03:05 AM
sam_b03's Avatar
make sure your rear wheel is straight. If it is crocked the steel change is going to grind the edge of your sprockets.
sam_b03 is offline
Map of Metal.... okie The Out House 6 06-26-2011 04:22 PM
found brass flakes in my oil copperelite Performance and Tech 15 01-20-2011 07:22 AM
Metal covers 925stunna Pictures and Videos 3 05-13-2010 07:40 PM
what is METAL ??? erikspeed The Out House 8 11-23-2008 07:11 PM
06 ZX10 Gun Metal zero lash Pictures and Videos 9 04-11-2008 07:48 PM
