Melted Radiator - Kawasaki ZX-10R.net
post #1 of 7 Old 09-18-2010, 01:31 AM Thread Starter
Melted Radiator
Took my leaking radiator off today to find it's leak in the middle of the backside of the radiator. Upon further examination of the problem, i noticed an evenly pressed in section of the radiator which appeared to have burn marks. I also found residue on the down pipes of a Brock's Sidewinder - full exhaust system. Concluding that somehow the radiator is touching the downpipes spot-melting it.
Has anyone had this problem before and if so, how did you fix it?
Pics:
Gojust is offline
post #2 of 7 Old 09-19-2010, 10:31 PM
redline659's Avatar
More than likely it didnt melt it but rubbed up against it at speed. If you put it all together push back on the radiator and see if it rubs against it
redline659 is offline
post #3 of 7 Old 09-19-2010, 10:37 PM
BratNetwork's Avatar
Aluminum melts at over 1200*F
BratNetwork is offline
post #4 of 7 Old 09-19-2010, 10:44 PM
gazx10's Avatar
radiator bracket
i always space the bottom support bracket out more, i like the radiator a little farther away from head pipes. lots of heat there to soak when still or idling. i agree with redlines, thats a contact, not melt hole. space bracket for clearance also.
gazx10 is offline
post #5 of 7 Old 09-19-2010, 11:10 PM
Chickenstrip Eater
SUPER K's Avatar
Send a message via MSN to SUPER K
If its a stock setup I'd call Brocks and ask if they are aware of any clearance issues.
SUPER K is offline
post #6 of 7 Old 09-20-2010, 10:48 AM
gazx10's Avatar
radiator clearance
just space radiator out and chalk it up to learning experience. this is how we learn to ck things like this. not all bolt ons are exactly that, my ti force came with a longer replacment bracket so there was no interference. i spaced it even more. ive made the same mistake over the years, and learned from them.
gazx10 is offline
post #7 of 7 Old 09-21-2010, 03:24 AM
bugman53's Avatar
It can be fixed. Aluminum brazing rods would fix her right up. ALmumoloy sp? That stuff works!
bugman53 is offline
melted 2 sets of jumper cables today 10roller The Out House 4 04-13-2009 12:54 AM
Melted gauges from chrome screen ?? zed-x user General Motorcycle Discussions 3 08-16-2008 09:39 PM
melted fan?!? *Pics colinmitchell111 Performance and Tech 20 11-08-2007 07:36 AM
06 Radiator Different than 04/05 Radiator??? Vonstallin Performance and Tech 2 12-29-2006 02:31 PM
Need help!! melted fairing!!!! bigorange10r The ZX-10R 9 04-15-2006 09:16 PM
