mechanics help.... - Kawasaki ZX-10R.net
post #1 of 28 Old 12-02-2009, 08:51 AM Thread Starter
red636girl's Avatar
mechanics help....
Had to change two fuses in my bike from 10amps to 15 amps, one was the marker/brake lite fuse and the other was the head lite fuse. Fuses kept blowin only on 10amps.
So if it were your bike would you be concerned?
Just scared Im goin to screw up my wiring in my bike.
Thanks
red636girl is offline
post #2 of 28 Old 12-02-2009, 09:03 AM
firedude's Avatar
Do not put bigger fuses in. You can burn wires like that. You have a wire or two with a short or a bad connection. This causes heat and resistance which blows the fuse. Trace these two systems down and really carefully check the wires and connections or take it in. Good luck.
firedude is offline
post #3 of 28 Old 12-02-2009, 09:03 AM
10RNOOB's Avatar
Something is causing excess current draw on those lines. Its probably not a good thing to leave alone. Might want to check over your wires and connectors. I have not experienced this on my bike personally, so I'll wait for others to chime in with more details. But definitely something to be concerned about.
10RNOOB is offline
post #4 of 28 Old 12-02-2009, 09:22 AM
Even a high load circuit like the headlamp should be drawing less than 5 amps or so....I don't see any way that a properly functioning bike should be blowing 10 amp fuses. unless you have heated gloves, auxilliary 60w PIAA headlights, gps, and air horns all running on the same circuit, 10 amps should be enough.
I'd start looking for an intermittant short. They're hard to find...a good wiggle test will sometimes fix it forever.
If it aint broken, it doesn't have enough features yet
There are 'glass half empty' people, and 'glass half full' people. Then there are engineers who see that the glass is twice as big as it needs to be.
Chubbs is offline
post #5 of 28 Old 12-02-2009, 09:23 AM Thread Starter
red636girl's Avatar
But the thing is, I have never had a issue with the fuses blowin until i put these new bulbs in, that are brighter, and when I put the stock bulbs back in she doesnt blow so you still think there is a short somewhere in the wires?
post #6 of 28 Old 12-02-2009, 09:24 AM Thread Starter
red636girl's Avatar
The only other thing i have on her is a gear indicator and Im not really sure where that wire goes into
post #7 of 28 Old 12-02-2009, 09:32 AM
diesel10R's Avatar
i'd double check all the bulbs to be sure they are correct,then check your wires/terminals at the connectors,may have pinched together when replacing bulbs(grabbing marker connectors w/pliers,ect.), also never up the amps...very dangerous...like stated only a short will blow a fuse...so retrace your steps......don't need to fine pile of ash instead of your bike good luck
Dan
ride or die!::weed :
diesel10R is offline
post #8 of 28 Old 12-02-2009, 09:57 AM
themightymezzo's Avatar
Are you sure you got the right bulbs? It's not blowing with the 15A fuses but is with the 10A? If it is a short I would think that the 15A would blow as well...although it's possible it wouldn't. And you also stated that when you put the stock back in and the 10A fuse in they don't blow then either. I'd check the ratings on the bulbs just to be safe. That would be the easiest and quickest fix...if it's right then start looking for a short or other cause.
"You can't trust anyone, not even your own asshole; sometimes you think you're gonna fart and you sh*t."
themightymezzo is offline
post #9 of 28 Old 12-02-2009, 10:04 AM
Dan
I may be mistaken but I believe overloading a fuse will blow it as well.
If you have a device that uses normally 10A, you want to install a larger fuse then that so you would install a 15A. However if you wanted to "beef up" said device to something that will use 20A you will burn/blow the fuse. But generally if you design a system that will run normally 10A and protect it with a 15A fuse, you will not size wires, etc. for the larger current/demand across that line. Which is why it's not a good idea to increase fuse size as previously stated in this thread.
post #10 of 28 Old 12-02-2009, 10:07 AM Thread Starter
red636girl's Avatar
Im not sure what you mean the right bulbs....they are the right number H9 and H11, and others have order the same bulbs from this company and had no issues with there bike, the package says xenon Gas charged bulbs, 6000k. i got them from Star Lights
and yes when I put the 10amp back in with the stock bulbs no problems. Thats why I think it the bulbs, cause never had an issue and still dont until i put these new bulbs in.
? for our auto mechanics wicked The Out House 20 10-04-2009 11:56 AM
A&P Mechanics.... Nick.INF The Out House 9 05-15-2009 06:22 PM
Any mechanics in the house? srleadjb Performance and Tech 16 10-22-2008 05:50 PM
Car mechanics please help! mjg68901 The Out House 20 03-17-2008 11:08 PM
Any mechanics on here? BrockLanders The Out House 8 02-12-2008 10:06 AM
