Mechanic Question - Kawasaki ZX-10R.net
post #1 of 11 Old 11-27-2010, 02:55 PM Thread Starter
Mechanic Question
Got a quick question for the mechs. I have a 93 KX125 that I had rebuilt bottom and top. During break in the motorshut off and it wont start again (not seized).Iam getting spark and fuel and I also checked the reeds. The compression is at 100 which I think is low should it be around 175? I tried bumping and it would not start. What else could I possibly check. Timing is also dead on.
HELP
zixxer is offline
post #2 of 11 Old 11-27-2010, 03:58 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
If she's getting fuel and spark then there has to be something internal that's jacked up....especially if you say the compression is low.how long/hard was it ran after the rebuild? i'm not a master mechanic by any means but it sounds like something going on with a piston or ring/seal?
TMY10ER is offline
post #3 of 11 Old 11-27-2010, 05:05 PM
eurichs07's Avatar
Send a message via Skype™ to eurichs07
Does it sound like it wants to start at all? Make sure the top end torque specs are still good. Maybe u are lucky with some shitty gass. If you have low compression probably not so lucky.
eurichs07 is offline
post #4 of 11 Old 11-27-2010, 06:01 PM
badassjake's Avatar
is it good spark?....sometimes a plug can fail under compression.
badassjake is offline
post #5 of 11 Old 11-27-2010, 10:27 PM Thread Starter
just put in a new plug and it still wont start. It will only backfire once in awhile otherwise it does nothing. By the way it is a two stroke single cylinder.
zixxer is offline
post #6 of 11 Old 11-27-2010, 10:28 PM
green10's Avatar
Low compression can occur when a cylinder gets soaked with fuel.Was it hard to start when it shut off?could be shitty fuel.
green10 is offline
post #7 of 11 Old 11-27-2010, 10:37 PM Thread Starter
I could not get it running after it shut off. I was breaking in the motor pretty easy and when it started ran fine for the first tank. Went out today to take a quick blast and the bike would not go into the powerband for a good 20 minutes when it did hit it wasnt long before the motor shut down.
zixxer is offline
post #8 of 11 Old 11-27-2010, 10:42 PM
green10's Avatar
How old is the fuel?
green10 is offline
post #9 of 11 Old 11-27-2010, 10:45 PM Thread Starter
Got it today 93 octane mixed 32:1 with golden spectro.
zixxer is offline
post #10 of 11 Old 11-27-2010, 10:58 PM
green10's Avatar
Is the plug foweld or real black?
green10 is offline
mr. mechanic king_bushido Performance and Tech 1 07-24-2010 09:46 AM
Need a team mechanic GregGorman Track 0 07-22-2009 12:55 PM
Need a mechanic! 06_10R Performance and Tech 3 01-03-2007 10:16 AM
Need a SoCal Mechanic RickRoush03 The Out House 34 07-14-2006 03:54 PM
Fair Mechanic??? RaceZX The Out House 11 03-13-2006 05:32 PM
