Marchesini wheel problem? - Kawasaki ZX-10R.net
post #1 of 8 Old 06-22-2010, 07:54 PM Thread Starter
jcw
I received my magnesium wheels and when I unpack the rear, I found this seemingly misaligned rear bore.
The wheel bearing and the bore are definitely offset from one another. This is looking through the cush drive side.
I'm thinking trying to force the spacer through this would either 1) put undue load on the bearing or 2) not fit at all.
Any thoughts??? Am I mistaken?
jcw is offline
post #2 of 8 Old 06-22-2010, 07:59 PM
mullinax95's Avatar
The spacer in the middle of the wheel will align straight when you install the axle. Is that what you are talking about?
mullinax95 is offline
post #3 of 8 Old 06-22-2010, 08:01 PM
dirt ninja's Avatar
Images: 9
I dont believe the spacer goes through the sleeve/bore. I believe the sleeve/bore will align with the inner bearing if you move it with your finger.
Marchesini Magnesiums,Nassert beet,kawi cam,.45 headgasket,DJ PC/Ig.M/QS,velocity stacks,bmc race,gipro,sato rearsets,helibars,throttlemeisters,pazzo shorties,speedohealer,520 renthal sprockets,penske 8393 double clicker,traxxion dynamic springs,scotts stabilizer,lsl frame sliders,cox radiator guard,powerbronze hugger,puig DB,solo seat cover,Valentine1,dual low beam projectors,55w.hids, brembo superbike rotors,Goodridge superbike lines,nissin calipers and rizoma mirrors,mda123 battery.
dirt ninja is offline
post #4 of 8 Old 06-22-2010, 08:05 PM
mullinax95's Avatar
Yes that explains it a little better
post #5 of 8 Old 06-22-2010, 08:06 PM Thread Starter
jcw
Oh, the sleeve moves in there?
I think the spacer does cross the bearing and into the sleeve but don't quote me on it.
If that's the case, thanks! Scared the crap out of me.
I didn't want to bang the sprocket drive in and everything be seized up.
jcw is offline
post #6 of 8 Old 06-22-2010, 08:08 PM
mullinax95's Avatar
Yep.... go mount your wheels man!
post #7 of 8 Old 06-22-2010, 08:12 PM Thread Starter
jcw
Yup, the fu*ker moves in there.
Can you tell I'm anal retentive?
Rep sent.
Can a moderator change the title to Marchesini wheel NON-problem. :)
BTW, thanks to LPusa for the great price and pretty fast shipping.
jcw is offline
post #8 of 8 Old 06-22-2010, 10:58 PM Thread Starter
jcw
Thanks for the good info in another thread...
Originally Posted by MagicMavis View Post
You would think Marchesini would put some correct length bolts in the box, or a note to cut your stockers. If it was my product I would.
But yeah, several members have been down this road. Cut your stockers or buy the shorter stock ones.
I had some aftermarket Titanium bolts for the REAR WHEEL I bought from Yoyodyne. Although they were shorter, the shoulder of the bolt (where there is NO threads) was still to long (longer than stock) and it wouldn't tighten down even though it was NOT bottoming out on the back side against the hub.
Be VERY VERY careful with the rear wheel bolts as it is close on the countersunk "well" of the bolt shoulder bottoming out. I stripped one of the holes and wound up using the longer bolts with lock nuts on the backside. I later bought another brake rotor mount. Costs was only $49.00 for that piece but took 6 months to get it.
Do not tighten anything down that doesn't look or feel right. Don't screw it up. Its easy to do. Take a LONG DEEP breath first, before damaging something you will cry over after wards.
jcw is offline
this is why im ordering Marchesini Forged Aluminum Wheel Kawasaki ZX10R anthonyzx10r2008 The ZX-10R 76 01-03-2016 11:27 PM
Marchesini Wheel Group Buy edouble Vendors deals 9 06-09-2010 11:54 PM
anyone waiting for there Marchesini Forged Aluminum Wheel 08 zx10r ? anthonyzx10r2008 The ZX-10R 88 08-27-2009 07:02 PM
Wheel or fork problem? tander2114 The ZX-10R 8 11-19-2007 09:03 AM
Front Wheel Problem Breck912 The ZX-10R 7 05-16-2006 12:17 PM
