Maintenance ?'s - Kawasaki ZX-10R.net
post #1 of 3 Old 11-15-2008, 09:40 PM Thread Starter
Postwhore with an 04
bcm0018's Avatar
Maintenance ?'s
Since riding season is pretty much over I am going to start my winter bike projects soon and had a ?
I am going to do a thin HG, intake cam, valve springs, ignition module, and the brake upgrade.
Since I am going through all this I was also going to sync the throttle bodies while I am at it but is there anything else I should do? Valve clearance? anything else?
Bike has a lil over 9000 miles.
Thanks
bcm0018 is offline
post #2 of 3 Old 11-16-2008, 12:47 PM
SpazOnaZX's Avatar
....well, you should check the clearances on the new cam when it goes in... that's pretty much a given. Other than topping off the gas tank, I'd remove the battery and set it up on a a battery tender.
If you're really in the mood, change your fork oil (or fork and shock springs if they're not set up for your weight). Give the chain a healthy coat of goo to keep it from rusting. Wheel bearings get ignored a lot: cleaning & re-greasing the seals and bearings is a good one. Coolant changes should be done about evey 2 years they say... I do mine every season as I switch from straight WaterWetter to anti-freeze in the winter. Fresh oil & filter are another given.
...and brake calipers are always in need of some love and attention. Clean pistons are happy pistons. :) Some fresh RBF600 in the lines is always a pleasant feeling. Need any more? ;)
SpazOnaZX is offline
post #3 of 3 Old 11-16-2008, 09:42 PM Thread Starter
bcm0018's Avatar
Thanks spaz! Any other advice?
bcm0018 is offline
Western PA Maintenance kiloalpha Regional Forums 0 05-10-2008 03:32 PM
A possible lack of maintenance? TheTurd Pictures and Videos 9 11-29-2007 05:27 AM
How many of you do your own bike maintenance 06450F Performance and Tech 37 12-23-2006 01:43 PM
CO Maintenance ctg1177 The Out House 0 08-20-2006 01:35 AM
Annual Maintenance Ground Zero The ZX-10R 1 06-11-2005 07:57 PM
