Lower? - Kawasaki ZX-10R.net
post #1 of 6 Old 05-28-2007, 06:20 PM Thread Starter
Lower?
Can i lower my bike with the stock shocks?
I don't want to come up as quick in 1st gear.
Any advice?
Thanks in advance
T3MPO is offline
post #2 of 6 Old 05-28-2007, 06:29 PM
Yankee Racer
zx10ragentblack's Avatar
Images: 9
Send a message via Yahoo to zx10ragentblack
Any advice?
Thanks in advance
You can remove the 3mm shim in the stock shock but that is all as far as lowering the rear shock goes.
zx10ragentblack is offline
post #3 of 6 Old 05-28-2007, 07:30 PM
Speed Freak
garth285's Avatar
a number of people sell lowering links, they replace the rear dogbones and you can lower anywhere from 1 -3 inches.
check out ebay.
garth285 is offline
post #4 of 6 Old 05-28-2007, 07:39 PM
mjg68901's Avatar
check out ebay.
Or any one of the site sponsors.
http://www.racemph.com/
Heavenly Father, thank you for your Word which is the Truth that sets me free. Give me strength to separate myself from anything that does not honor You. In Jesus Name. Amen.
mjg68901 is offline
post #5 of 6 Old 05-28-2007, 08:11 PM
Supercharged Mod
Remember, if you drop the rear ride height you should drop the front as well to keep the steering response in the ballpark. First guess, same amount (measured at the wheel) as the rear. You can only go SO far with lowering the front before the front fender will collide with something before it runs out of compression travel, and you don't want that happening ...
I installed a chain with a few more links than stock to get the back wheel to the back of the adjustment slot to help keep the front down. 'Course, that came along with a 2 teeth bigger rear sprocket, so now it launches even harder and the front still wants to come up. Hehe, it's all good :-)
GoFaster is offline
post #6 of 6 Old 05-29-2007, 10:27 PM
strictly lowering your bike will not keep the front end down. if it's really a problem, (can't see how) extend the swing arm (effective), or soften the compression on the rear (not very). Just remember any thing you do will adversely effect the handling. You could just roll on slower and lean over the tank more!
matt is offline
need to lower wanaride23 The ZX-10R 7 05-25-2007 03:15 PM
WTB right lower and mid stunterdude Wanted: Buy or Trade 1 01-02-2007 11:32 PM
lower first gear mod Vince10R Performance and Tech 21 06-08-2006 11:53 PM
wtb: lower cowlings Till_I_Die Wanted: Buy or Trade 0 03-24-2006 11:27 PM
FS: Lower for 05 10r kwakman Parts, Gear and Accessories 9 04-24-2005 05:49 PM
