looking for suggestions of valve shim kits. - Kawasaki ZX-10R.net
post #1 of 6 Old 11-07-2007, 07:46 PM Thread Starter
Speed Freak
garth285's Avatar
hey guys, well some of you know I got the 10r all apart for the 06-07 fairing conversion.... I needed to do my valves for a lil while now so I figure while I got her apart I might as well do everything Ive needed to do to her now while I can.
So tonight I got her prepped up until the valve cover ready to be taken off to dig into the valves. I just need to get some tools for the job but looking to see what brand of shim kits any of you have used or how you went about doing it. I used a hotcams box set when I was working at a shop but wondering if theres any others you guys might suggest.
HIT ME UP!!!!!
garth285 is offline
post #2 of 6 Old 11-07-2007, 07:57 PM Thread Starter
Speed Freak
garth285's Avatar
also anyone know what size shims they are.... 7.48mm or 9.48mm I'm thinking the 7.48 but not sure??? Haven't been inside a 10r in 4 months or so lol...
garth285 is offline
post #3 of 6 Old 11-07-2007, 11:05 PM
sextaafondo's Avatar
Garth,
why do you want to use aftermarket shims, rather than using Kawasaki´s?
You can use this formula to calculate the shim thickness needed, and buy just what you need:
a. Present shim thickness
b. Measured valve clearence
c. Specified valve clearence (Mean value = 0.195mm)
d. Replace shim thickness
Formula : a + b - c = d
Example:
1.600 + 0.31 - 0.195 = 1.715
I get this formula from the service manual.
Pablo
sextaafondo is offline
post #4 of 6 Old 11-07-2007, 11:11 PM Thread Starter
Speed Freak
garth285's Avatar
its about 12 bux a shim from the dealer and 9 bux on ronayers..... a shim kit is about 80-90 bux and comes with a whole lot more of them. also I dont wanna rely on someone messing up a simple order and waiting on new shims to come and this and that..... I wanna do it all in one shot and not have my head open for a few days.
garth285 is offline
post #5 of 6 Old 11-07-2007, 11:12 PM
FAF
Rent this space
FAF is offline
post #6 of 6 Old 11-08-2007, 08:40 AM
Thats a good point. I didn´t know prices either.
Increments are at .05 instead of oem .025 Should be fine anyway.
04-07 cam shim kits jimbob8915 Performance and Tech 9 12-09-2010 09:15 AM
Valve shim Question WTtoolman Performance and Tech 5 04-02-2007 01:56 AM
Removing rear shock shim (adding trail) ?? OmegaX Performance and Tech 17 10-04-2006 10:32 PM
Removing Rear Shock Shim TheReb Performance and Tech 15 07-02-2006 05:14 PM
how important is the valve shim adjustment at first service. liljunglist2 The ZX-10R 8 07-05-2004 09:53 PM
