Looking for 04-05 10r injector flow rate specs - Kawasaki ZX-10R.net
post #1 of 23 Old 08-21-2008, 11:20 AM Thread Starter
hey all, newb to your forum here. I'm building a bike engined car and using a set of 04-05 zx10r throttles and FI setup on an older carbureted honda motor. running a megasquirt to control everything. I've spent a few hours searching to no avail looking for flow rates for the stock injectors. I did find a factory service manual for an '04 but no specific injector flow rates are specified at any fuel pressure. I have the injectors on hand but would really like to avoid having to build a test rig to find out what they are.
thanks all!
bluej is offline
post #2 of 23 Old 08-21-2008, 11:50 AM
FAF
Rent this space
Google the part number on the injectors , you will get the answer from the manufacturers website.
I have done this for injectors before.
FAF is offline
post #3 of 23 Old 08-21-2008, 12:13 PM Thread Starter
tried that. no dice. part number on the sides are: 28403y3
not sure who the injector manufacturer is. it has the bosch style connector, but says "bosch license" inside so i'm assuming that they are not bosch injectors and only use the connector style. confirmed this as well as I could searching the bosch website and others looking for a part number or application match with no luck.
bluej is offline
post #4 of 23 Old 08-21-2008, 01:32 PM
Images: 11
try mitsubishi, look at our efi computer and you'll know why I suggest this
Its just a guess though.
firerescue212 is offline
post #5 of 23 Old 08-21-2008, 01:35 PM
bugman53's Avatar
Dont hold me to this but i thought the stock injectors would support 250-300hp
High Velocity Cycles 2005 Ti ZX10R
Greeensboro NC
bugman53 is offline
post #6 of 23 Old 08-21-2008, 02:23 PM Thread Starter
some quick math with assumed BSFC and DC gives a range from 260-320 cc/min. at stock fuel pressure. I really need to nail down that number for calculating some base maps to start from, that's just a little too broad. Do any of you know max Duty Cycle on a stock bike? and likewise BSFC?
thanks for all the input everyone!
bluej is offline
post #7 of 23 Old 08-21-2008, 02:42 PM Thread Starter
good lead, they appear to be nippon injectors. just need to find specs for this particular part number.
or
http://www.nikk.co.jp/english/product.html
bluej is offline
post #8 of 23 Old 08-21-2008, 02:51 PM Thread Starter
good lead!
turns out they are nippon injectors.
Originally Posted by Nippon Company History
September 2002 Started production of EV6/CA type injectors for Kawasaki Heavy Industries, Ltd. and Yamaha Motor Co.,Ltd.
Started production of EV6/CB type injectors for Mitsubishi Motors Corporation
looks pretty damn familiar
website also says that they are basically a 50/50 shareholder company of mitsu and bosch so that fits as well.
bluej is offline
post #9 of 23 Old 08-21-2008, 02:59 PM
Speed Freak
garth285's Avatar
if you look inside the plug area you will see bosch inside them, they are the same fuel injectors for the zx12r as well (thats for 04-05 zx10r) on 06-07 they are a different injector and they are the same as for the zx14......
garth285 is offline
post #10 of 23 Old 08-21-2008, 04:08 PM Thread Starter
woohoo!!! scored the data needed.
http://www.factorypro.com/ these guys advertise flow check and balancing for sport bike injectors so i found them and gave them a call and they gave me the following data for these specific injectors:
110 mL
20 s
100% DC
3bar FP.
so at the bikes stock FP and 100% DC they are appx. 330 cc/min injectors.
these guys were super helpful so don't hesitate to use them for any injector needs!
bluej is offline
04-05 Stock injector #'s? 1killer1liter Performance and Tech 9 05-27-2008 11:32 AM
over flow res with 06 /07 rad mod? avdigigeek Performance and Tech 22 04-04-2008 11:18 AM
05 zx-10 Fuel injector CC rating? Vince10R Performance and Tech 4 02-26-2008 09:25 AM
Injector Cleaner jpaterson Performance and Tech 13 03-29-2006 09:30 PM
Injector Cleaners BigDally The ZX-10R 5 03-13-2006 09:36 AM
