Little help...removal 2nd gen. fuel cap - Kawasaki ZX-10R.net
post #1 of 11 Old 03-28-2008, 11:11 AM Thread Starter
okay i just bought a use tank to swap the dented tank on my bike.
how do i take off the fuel cap ass'y?...i took off the 5 allen bolts, is there something else?
NYZX10R is offline
post #2 of 11 Old 03-28-2008, 11:14 AM
bkkninja's Avatar
Do you have the key for the fuel cap? You will need it to remove cap once all bolts are out.
bkkninja is offline
post #3 of 11 Old 03-28-2008, 11:24 AM Thread Starter
Nope!.... drill out the lock?
NYZX10R is offline
post #4 of 11 Old 03-28-2008, 11:25 AM
bkkninja's Avatar
yep.
bkkninja is offline
post #5 of 11 Old 03-28-2008, 11:37 AM Thread Starter
Thanks!...didn't want to do that though!
So what under the gas cap that holding it down?
NYZX10R is offline
post #6 of 11 Old 03-28-2008, 11:40 AM
konichd's Avatar
Or take out the fuel pump and push the tabs in with a flat head screwdriver.
konichd is offline
post #7 of 11 Old 03-31-2008, 10:06 AM Thread Starter
fuel pump out.....i don't see any tabs?... there is a cover with spot welds w/two half moon opening...now what?
NYZX10R is offline
post #8 of 11 Old 03-31-2008, 02:45 PM
FAF
Rent this space
Turn the tank upside down, remove the fuel pump assembly , directly under the fuel cap you will see one big slot and 2 smaller oblong slots, in the two little slots you will see a phillips head screw which holds the bottom portion of the lock together , undo the two screws with a small philips head screw driver and the lock will fall into 2 pieces and you're done.
FAF is offline
post #9 of 11 Old 03-31-2008, 09:21 PM
Bought salvage bike for me and my son to rebuild, as a project, needless to say it had no keys for anything. Took to locksmith, $40 later and had one key cut to fit ignition, gas cap and rear seat. If you are wanting to use the gas cap then take the whole tank up there and they can do it. Only took about 15 minutes.
predator is offline
post #10 of 11 Old 04-01-2008, 02:03 PM Thread Starter
That easy writing then done! i can't even put 4 fingers in the tank....
NYZX10R is offline
fuel tank removal?? ninja10 Performance and Tech 5 08-30-2007 09:22 PM
Fuel filter removal FAF Performance and Tech 26 07-16-2007 11:34 AM
Local San Diego Fuel tank rust removal, help! conspiracy The Out House 3 11-04-2006 03:50 PM
WTB Fuel tank/Fuel pump bellevuetlr Wanted: Buy or Trade 2 12-13-2005 08:43 AM
Fuel tank removal Zed Performance and Tech 9 06-18-2005 08:20 AM
