little help, rear master cylinder. - Kawasaki ZX-10R.net
post #1 of 3 Old 08-18-2006, 01:58 PM Thread Starter
I need to take off the rear master cylinder because I'm going to have it painted, among other things on monday. Never messed with brakes before. What steps do I do to have minimal mess? I think I'm going to just have it put back on at a dealer with a carbon/stainless line because I've heard it's a pain. Would it be tough for me to reconnect everything? I'm pretty good with tools, in that I do all regular maintanence myself.
thanks for the help!
hotstang46 is offline
post #2 of 3 Old 08-18-2006, 02:03 PM Thread Starter
while I'm asking too, anyone happen to know what size rivets are used on the AKRA exhaust? I'm going to have the silver bands and the metal piece that is at the end of the sleeve that bolts to the piping painted as well...
should I be able to find black rivets?
post #3 of 3 Old 08-18-2006, 02:04 PM
Still here
ZX10Miami's Avatar
It's really easy.
1st remove the brake fluid by "bleeding" from the nipple(s) at brake.
Then remove MC.
Install is easy, just have to bleed the brakes which is real easy with a mighty vac.
Other than that, just don't overtighten anything (strip threads or brake the banjo bolt) or over-crush the crushwashers.
http://www.cyclegear.com/spgm.cfm?L1...=PAR_DS-310207
ZX10Miami is offline
doing r1 master cylinder, which lines to get joedirt199 Performance and Tech 3 06-22-2006 08:37 PM
Brembo master cylinder hedgeseekinmisssile Vendor Deals 1 02-27-2006 09:18 PM
ZX10R master cylinder fatrock The ZX-10R 10 02-10-2006 02:00 AM
'06 Master Cylinder Older Guy The ZX-10R 7 02-09-2006 10:08 AM
Radial master cylinder? lunitk The ZX-10R 2 01-25-2006 10:19 PM
