Gen 1: 2004-2005 Limp Mode 8K RPM - Kawasaki ZX-10R.net
post #1 of 6 Old 07-07-2014, 08:05 AM Thread Starter
Wallpapereater's Avatar
Limp Mode 8K RPM
I got the bike together and she is running great... to about 8k RPM.
When I get to about 8K or so she goes into limp mode.
It almost feels like leaving the choke on, on an old carb'ed bike. Bogs out.
I read up and it looks like it could be a few things.
I just went out side and it revved up to red line in neutral. (Fire shot out of the exhaust. It was awesome!)
I'm thinking it is Neutral sensor.
I'll check it out later today when I repaint my tank white.
Will update with pics later.
Wallpapereater is offline
post #2 of 6 Old 07-09-2014, 12:39 AM Thread Starter
So my bike is in limp mode and I'm throwing a FI light code 32.
I'm thinking the easiest way to fix the problem would be to buy a new set of throttle bodies and swap out the old ones.
Would this be a good route to go? http://www.ebay.com/itm/2004-2005-Kawasaki-Ninja-ZX10-ZX10R-Throttle-Bodies-Injectors-Carbs-Fuel-A156-/301233346479?pt=Motorcycles_Parts_Accessories&hash =item4622e817af&vxp=mtr
post #3 of 6 Old 07-13-2014, 10:14 AM
horsePOOGAS's Avatar
why do you need to replace the whole throttle body assembly? Why not just start with the sensors on the set you have and replace them?
horsePOOGAS is offline
post #4 of 6 Old 07-20-2014, 01:36 PM
keithk's Avatar
so,..... what happened?
Its green and it says Kawasaki ninja zx10r on it!
keithk is offline
post #5 of 6 Old 07-20-2014, 03:07 PM
Newfie Bullet
craig_sez's Avatar
Images: 34
On the gen 3,to replace the sensors you gotta split the #2 #3 tb to get at the lil sensor thingys...I started to do mine but stripped the heads on the tb flys...So i ended up finding an almost new set of tb on ebay..
craig_sez is offline
post #6 of 6 Old 07-21-2014, 10:37 PM Thread Starter
Got it!
The problem was with the PCIII. It must have lost it's map or something. I disconnected it and am running stock ECU. I took it out for a ride and I just got to say....
HOLY SHIT!!!!
I can't believe people put turbos on this bike.
I've had 4 bikes before this one and this thing is stomach-dropping... ball tingling.. mind-numbing.. holy SHIT! Fast!!
Jesus... I've never felt torque like that before.
700hp shelby vs gix 750 , 2012 zx10r in 1k mode, 2012 zx10r in 600 mode whans1980 Pictures and Videos 34 09-12-2013 01:50 PM
Limp mode ?????? cow10r The ZX-10R 2 01-22-2011 10:15 PM
new mode on my GREEN.... Tomsa Pictures and Videos 19 03-26-2009 02:01 AM
Will ECU go into a limp mode if sceondary actuator is un plugged? garth285 Performance and Tech 12 06-04-2007 09:08 PM
Depeche Mode finally cain772 The Out House 12 09-20-2005 08:51 PM
