Leaky countershaft seal? - Kawasaki ZX-10R.net
post #1 of 15 Old 11-13-2005, 11:01 AM Thread Starter
lavudyar's Avatar
Send a message via Skype™ to lavudyar
Hey - any of you guys in cold climates have the countershaft seal leak a little at sub-freezing temperatures? I have been out of town for a while and when I got home it was just after our first below 32 night. I noticed oil on the garage floor under the chain (definitely oil, not lube) so I am assuming the cold weather caused the seal to be less than perfect. Can anyone confirm? And is there anything I can do to help the situation?
Ray D
Never pet a burning dog.
lavudyar is offline
post #2 of 15 Old 11-13-2005, 12:06 PM
ninja9rc's Avatar
I doubt that temperature caused that... over tightened chain can sometimes be the cause of seal failure.
'05 ZX10R Titanium
'96 Dodge Viper
'09 Maxima SL
'01 Xterra
'96 Rottweiler RIP Zeus
'98 Rottweiler
'08 Cane Corso
ninja9rc is offline
post #3 of 15 Old 11-14-2005, 07:29 PM Thread Starter
lavudyar's Avatar
My chain is loose if anything - any other thoughts? It is truly perplexing to me.
Ray D
lavudyar is offline
post #4 of 15 Old 11-14-2005, 07:38 PM
Big Daddy's Avatar
Images: 38
Yea i doubt its the cold temps so my only thought is the seal has failed and requires replacement. If its under warranty i would consider that.
Big Daddy is offline
post #5 of 15 Old 11-14-2005, 07:54 PM Thread Starter
lavudyar's Avatar
I should have explained better - the bike has been sitting for at least 8 weeks (I know, but I've been working out of state for that long and now winter's here). You guys don't think it's possible for the shaft to contract faster than the seal?
Ray D
lavudyar is offline
post #6 of 15 Old 11-14-2005, 08:33 PM
Big Daddy's Avatar
Images: 38
the metal will certainly contract more than the rubber so just maybe, but then what happend last winter??
post #7 of 15 Old 11-14-2005, 08:57 PM
ninja9rc's Avatar
If your chain is loose and you didn't damage the seal when removing the front sprocket the seal either failed or dryed out... seals have a spring in the i.d. that keeps the rubber on the metal and this spring sometimes breaks (rare)... also, seals are actually wedged in giving them a cushion of rubber on the o.d. to make up any small differences due to expansion/contraction and imperfections otherwise they would just fall out... the only explanation could be that you changed to synthetic oil... did you?.
Just had another thought, did you pressure wash the bike before you left it, could be that water penetrated the seal and froze causing it to rip.
'05 ZX10R Titanium
'96 Dodge Viper
'09 Maxima SL
'01 Xterra
'98 Rottweiler
'08 Cane Corso
ninja9rc is offline
post #8 of 15 Old 11-14-2005, 09:18 PM Thread Starter
lavudyar's Avatar
I moved from CA to OH this April and didn't get the bike until May. No synthetic oil. Changed the front sprocket a few months ago and the problem just now showed up. I'm going away this week as well and it's supposed to be fairly cold here, so I guess I'll see if the problem continues. Thanks for the thoughts and I'll keep you all posted.
Ray D
lavudyar is offline
post #9 of 15 Old 11-14-2005, 10:07 PM
ninja9rc's Avatar
BINGO!!... more likely than not that's what caused the eventual failure..
'05 ZX10R Titanium
'96 Dodge Viper
'09 Maxima SL
'01 Xterra
'98 Rottweiler
'08 Cane Corso
ninja9rc is offline
post #10 of 15 Old 11-15-2005, 06:33 PM Thread Starter
lavudyar's Avatar
I hope not - I'm sure that's not gonna be under warranty!
Ray D
lavudyar is offline
First ride with 16t countershaft sprocket... El Diablo Performance and Tech 92 09-03-2006 06:44 PM
Fork seal update... Ground Zero Performance and Tech 4 07-28-2005 01:23 PM
Fork Seal leak - Danger? Finatic-1 Performance and Tech 17 06-18-2005 07:48 AM
BREAK IN PROCEDURES FOR MAX HP TRUE OR FALSE? zixxer Archives 29 11-01-2003 12:43 AM
