leaking forks - Kawasaki ZX-10R.net
post #1 of 5 Old 08-18-2008, 03:58 PM Thread Starter
nyrep1's Avatar
leaking forks
i had a buddy tell me my forks are leaking (05 6800miles) i asumed he said this b/c of oily film on black part of forks, but i looked at a brand new bike the other day and it had comparable amount of residue on its fork tubes, so my question is how am i to be sure they are leaking?
nyrep1 is offline
post #2 of 5 Old 08-18-2008, 04:04 PM
10R Joe's Avatar
Images: 9
You'll know within 30mins of riding. If they're leaking oil will be everywhere...breaks, rim, tire...be careful & don't go leaning into turns @ 100mph until u know for sure they aren't leaking.
If its got tits or tires it'll give u problems
10R Joe is offline
post #3 of 5 Old 08-18-2008, 04:05 PM
Retired post whore
Alien10's Avatar
A light oily film is normal. You'll now when they are leaking when the oil is running down the fork leg and dripping off on to the rim like my 04's did when they went.
Alien10 is offline
post #4 of 5 Old 08-18-2008, 04:14 PM
Images: 24
If you can wipe the fork stanchions (part that slides into the main fork tube) with your finger and it turns up wet and/or shiny on your finger, I'd say they were leaking. It's just to what extent you're gonna be concerned with next. Sometimes, if there are not that bad (ie: dripping onto the floor or rim), I've found that working a business card an inch or so up into the fork past the seal and going around the fork while pulling the card back out slowly will tend to "revive" the seals somewhat. Tends to get the dirt and crud out from the seal lip that the dust covers let pass.
Big Red is offline
post #5 of 5 Old 08-21-2008, 08:18 AM
zed-x user's Avatar
Morning, if it turns out you do need to replace your fork seals, at my shop we have been using All balls dirt bike seals, they work great, started using them because my zx12r would eat fork seals for lunch, almost every time I would have to drop it down from a wheelie quick and hard, for many reasons but usually a cop, that heavy thing would pop seals, tryed all sorts of different brands including stock and the only thing that stays sealed are the All balls seals, we have been putting them on every set of forks we do know, they only list them in the dirt bike catologs but when you get the pack it says on the back all of the street bikes they fit also, all you have to do is match up seal sizes.
zed-x user is offline
my 10 is leaking oil.... please help poohbear The ZX-10R 14 10-16-2006 10:01 PM
front forks started leaking**UPDATE 7/12** loueber The ZX-10R 37 07-16-2006 09:05 PM
exhaust keeps leaking mikebar4 Performance and Tech 6 04-19-2006 10:53 PM
Fork Leaking? 05Ti10 Performance and Tech 6 07-16-2005 04:45 AM
Does anyone know if the front forks can be swapped with forks from another model liljunglist2 The ZX-10R 2 02-04-2005 01:39 PM
