leak down test? - Kawasaki ZX-10R.net
post #1 of 12 Old 06-13-2010, 11:14 AM Thread Starter
tone.r's Avatar
leak down test?
My bike is very loud to me, will a leak down test let me know if i have a cracked retainer?
Tone.R {checkmate}
Do what makes u happy whatever it is.....Roberson Racing
tone.r is offline
post #2 of 12 Old 06-13-2010, 11:17 AM
Vio
Vio's Avatar
Probably not.
My bike did not sound any different when it had 7 broken retainers than it did after i replaced them with kibblewhite titanium retainers except the ticking noise went away
Vio is offline
post #3 of 12 Old 06-13-2010, 05:56 PM Thread Starter
tone.r's Avatar
Originally Posted by Vio View Post
Probably not.
Thanks man im not having any power lost but i can hear a ticking noise new motor about 200 miles on it. did you do springs or just retainers?
Tone.R {checkmate}
tone.r is offline
post #4 of 12 Old 06-13-2010, 05:59 PM
Vio
Vio's Avatar
I did springs and retainers on mine.
The ticking you are hearing could be the cam chain tensioner. Try putting the bike in 5th gear and rolling it backwards a few feet and see if the ticking goes away.
I doubt you have any broken retainers if you only have 200 miles on the motor.
Vio is offline
post #5 of 12 Old 06-13-2010, 06:00 PM
bluedevil's Avatar
your sure it's not the Cam Chain Tension er?....it causes Mad ticking noises as well if out of wack.
bloo
bluedevil is offline
post #6 of 12 Old 06-13-2010, 06:26 PM Thread Starter
tone.r's Avatar
let me re-state my motor about 200mile on the new pistons and tranny. thanks guys for your help.
Tone.R {checkmate}
tone.r is offline
post #7 of 12 Old 06-13-2010, 06:27 PM
Vio
Vio's Avatar
Do you by chance know if the retainers were good before you did the pistons and tranny?
The only real way to check them is to pull the head off and inspect them unfortunately. My bike showed no signs that there was anything wrong, although i had 7 valves that were close to dropping.
Vio is offline
post #8 of 12 Old 06-13-2010, 07:32 PM Thread Starter
tone.r's Avatar
all retainers was fine before the work.
Tone.R {checkmate}
tone.r is offline
post #9 of 12 Old 06-13-2010, 09:05 PM
Vio
Vio's Avatar
I would be willing to bed that you are fine.
Is it possible you are just being paranoid because you had major work done? I know I would be :)
Did you set valve clearances before doing the work?
Vio is offline
post #10 of 12 Old 06-14-2010, 03:45 AM
tasos's Avatar
The ticking you hear is normal, especially in the hot days.
Mine does it too.
tasos is offline
Oil Leak. anaxagoras1986 Performance and Tech 10 03-24-2010 05:23 AM
Help with a leak.... 1bad10r Performance and Tech 9 02-04-2009 09:49 PM
HELP!!! Oil leak! steeleballs420 Performance and Tech 4 09-09-2007 01:46 PM
Radiator leak '07 daffy67 Performance and Tech 0 05-03-2007 01:59 AM
Exhaust Leak???? RickRoush03 The ZX-10R 2 05-18-2005 07:21 PM
