launch control/kit ecu - Kawasaki ZX-10R.net
post #1 of 15 Old 07-09-2012, 02:03 PM Thread Starter
Hi, has anyone setup/used launch control or used the pit lane limiter as a launch control function.
I have a zx10r 04/05 engine with kit ecu in my hillclimb car and wondered if I could make use of this to improve my starts.
Sorry if this has already been discussed but i can't find it so maybee someone can help me out.
Cheers
Rob
multisport is offline
post #2 of 15 Old 07-10-2012, 01:31 AM
Balogiannis's Avatar
Send a message via MSN to Balogiannis
Cheers
Rob
I'm using the launch control on my 08 ZX10,it's pretty easy. Once you set it up through the software,it's activated as long as you have 1st gear in the gearbox and the clutch pulled...
Once you release the clutch and the bike starts to roll it gets deactivated automatically.It's default setting is 6.000 rpms and you can adjust it from 3.000 rpms up to 9.000 rpms...
Balogiannis is offline
post #3 of 15 Old 07-10-2012, 07:25 AM
thundercoupe9's Avatar
I don't think they have that option on 04-07.......... I don't remember seeing it on my 06, I'll check it tomorrow.
thundercoupe9 is offline
post #4 of 15 Old 07-10-2012, 11:20 AM Thread Starter
launch control
Hello Balogiannis,
Thanks for your reply. I checked the software I have, (from Lello), and it is adjustable from 5000 down to 1000 rpm by clicking and dragging.
What I could not quite work out was if it disabled after 1st gear, and if it would engage again if I had wheelspin in first. It sounds like the limiter stops working as soon as the clutch is released from what you have said or am I not understanding.
Also do you know which wire connections operate the quickshift function on the kit ecu.
Even in a car kawa brings a big grin to my face!
Cheers
Rob
post #5 of 15 Old 07-10-2012, 01:16 PM
Is Launch control only in the kit ECU? I'm assuming it is, but thought I'd ask.
Cocky Rooster is offline
post #6 of 15 Old 07-10-2012, 01:19 PM
Baddie's Avatar
Can I ask what software are you using to do that?
Baddie is offline
post #7 of 15 Old 07-10-2012, 05:24 PM
The software that comes with the race ECU,but I'm speaking for the 3d GEN bikes.
The options vary slightly depending on the model.
@ multisport
The launch control won't deactivate immediately after the clutch is released,but it'll keep until the bike reaches a certain speed or shift to 2nd gear,which ever comes first I think.
I'll check about the what pins you connect for the quickshifter but you can figure it out by checking the wiring diagrams in the race manual.
post #8 of 15 Old 07-10-2012, 11:43 PM
Baddie's Avatar
@ multisport
I no i have the last of the gen3 models (2010 )
Baddie is offline
post #9 of 15 Old 07-11-2012, 01:25 AM Thread Starter
launch control
Hi Balogiannis,
From what you have described, that sounds exactly what I had hoped for, deactivating once second is selected or hits preset speed.
I have kit ecu and race sofware and interface, bought from lello87 but don' know how it compares to the later bikes as my engine is 05 c2.
As far as quickshifter goes, I will troll through the posts for kit wiring diagram.
Also I think I will ask lello 87 if the new software that is coming will have traction control, will keep you posted.
Thanks again
Rob
post #10 of 15 Old 07-12-2012, 01:06 AM
Hi Balogiannis,
Thanks again
Rob
Rob I'm afraid I'll disappoint you. I cheked the available options for your model and it doesn't include launch control for the 04/05 model...
Using the pit limiter for launch control might me a good idea but you'll need to disable it manually after you launch...
Gen 3: what rpm to launch at? timmyriv Strip 11 05-10-2011 01:32 PM
Gen 1: how to launch skatermckimm Strip 27 04-11-2011 08:06 PM
MSD 2 Step launch control ZB10-R Parts, Gear and Accessories 2 12-21-2010 05:18 PM
2 step launch control Uwan Pictures and Videos 1 10-01-2008 06:51 PM
Need some launch help! rcoov00 Strip 26 08-22-2007 07:05 PM
