Known fix for shifting problem? - Kawasaki ZX-10R.net
post #1 of 29 Old 08-12-2005, 07:35 PM Thread Starter
When I occasionally get the balls to hold WFO through the gears, almost always when I go for third (clutchless), I end up still in second and overrev. It just doesn't pop in to third the way it should and it's bringin' me down.
BTW, the other day on just the right turn and surface, I got the bastard to power wheelie in third at about 130ish on corner exit. That's a new one to me. Unfuckin real.
P.S. Bike is still under warranty but I need to know if anyone has dealt with this yet. My dealer will take apart the whole bike before figuring it out, and I'd like to point them in the right direction.
Mark
youlose is offline
post #2 of 29 Old 08-12-2005, 09:56 PM
Hillbillie Mod
hillcountry10r's Avatar
Images: 31
Everytime I have that problem its cause I got lazy...
Also, depending on what type of oil youre running, it could be causing problems with the clutch...The fix for that is take it out and soak it in oil overnight and reinstall!
James 3:7,8
hillcountry10r is offline
post #3 of 29 Old 08-13-2005, 01:49 AM Thread Starter
Ummm, not getting lazy with the ol' foot. Trust me.
Am running Kawichem 20w50 dino-oil. 1800 miles
And this happens when clutchless upshifting, so I beleive that wouldn't effect the transmissions engagement? Never thought about that.
youlose is offline
post #4 of 29 Old 08-13-2005, 02:19 AM
Hillbillie Mod
Images: 31
Try the clutch thing...youll be glad you did...check out the how-to section!
James 3:7,8
post #5 of 29 Old 08-13-2005, 02:22 AM
grunty-motor's Avatar
try lowering the shift lever or going for the GP pattern - not a real fix but helps
Mmmm - let me have a think about that....
grunty-motor is offline
post #6 of 29 Old 08-13-2005, 08:11 AM
Andy's Avatar
Images: 25
I missed second a few times before I switche to GP style. Haven't had the problem since.
Andy is offline
post #7 of 29 Old 08-13-2005, 08:14 AM
Green Hippie
treyzx10r's Avatar
went gp also no problems ! Andy how much of the lower did you have to trim?
VAE VICTUS!
treyzx10r is offline
post #8 of 29 Old 08-13-2005, 08:16 AM
Rearsets will fix it. Sato, Arata, Attack, etc. All good. No more sloppy linkage = no more sloppy shifts. And for all the whiners, I know we shouldn't have to install aftermarket rearsets in order to have good shifting. A perfect world would be nice, but we live in this one, and you get better shifts with rearsets.
CanyonCarver is offline
post #9 of 29 Old 08-13-2005, 08:26 AM
Green Hippie
treyzx10r's Avatar
here is the sato in gp shift you will have to trim the lower a bit
VAE VICTUS!
post #10 of 29 Old 08-13-2005, 08:29 AM
MIA Post Whore
miykl's Avatar
As already said, lower the shift lever. Then buy rearsets.
2011 Ninja 1K street
2004 636 track
miykl is offline
Brake fade problem - I need advice... jr4488 Performance and Tech 29 07-07-2005 09:04 AM
Firefox Security problem (FIX RELEASED) Louks03 The Out House 5 05-12-2005 01:08 PM
Motor mount bracket problem.. Bobster Performance and Tech 12 04-25-2005 07:35 AM
TRE Related Problem & a Fix CanyonCarver Performance and Tech 15 04-15-2005 12:55 PM
Problem with Sato Pipe ballsup The ZX-10R 13 04-05-2005 07:15 AM
