Knock after Valve cover seal replacement - Kawasaki ZX-10R.net
post #1 of 9 Old 05-23-2012, 08:56 PM Thread Starter
WhackyWheels's Avatar
so when i turn it on it idles and keeps randomly knocking and the rpms spike about 200 each time that happens. any idea what could be wrong with it? no engine light.
WhackyWheels is offline
post #2 of 9 Old 05-23-2012, 10:15 PM Thread Starter
i seem to have fuel in my oil aswell, alot of fuel.
post #3 of 9 Old 05-23-2012, 10:19 PM
Valve cover wouldn't have anything to do with fuel in oil. Most likely a head gasket.
Sent from my LG-MS910 using Motorcycle.com Free App
shortskimper is offline
post #4 of 9 Old 05-23-2012, 10:19 PM
Also. Check fuel pressure regulator.
post #5 of 9 Old 05-23-2012, 11:18 PM Thread Starter
changed the oil just before the video and it doesn't seem to have fuel in it, must have been my imagination.
ha i kicked one of my empty beer bottles at the end XD. got pissed off by the unusual idle and started drinking.
post #6 of 9 Old 05-23-2012, 11:23 PM
Gen2 Ripper
neverendingmods's Avatar
Make sure the coil caps are aligned properly. They are lines on top of cap and on valve cover. Sounds like it is mis firing and dumping fuel.
neverendingmods is offline
post #7 of 9 Old 05-24-2012, 10:02 AM Thread Starter
it might be the spark plugs, the service manual fails to mention that you must screw in the coil plug not push it down. i pushed them down which strip the threading on the top of the spark plugs. going to the store now to buy new ones to see if it fixes it.
post #8 of 9 Old 05-24-2012, 12:00 PM
Sounds like you got a winner. Keep us posted
post #9 of 9 Old 05-24-2012, 12:57 PM Thread Starter
cleaned the throttle body with 99% isopropyl alcohol, replaced the spark plugs and cleaned out the coil packs with 99% isopropyl alcohol. installed them at the correct angle and it seems to be running correctly now.
How To: Fork Seal Replacement garth285 Performance and Tech 90 08-14-2019 11:26 PM
Valve cover gasket replacement interval Kawawog Performance and Tech 6 01-13-2012 07:13 PM
HOW TO: Fork Seal Replacement garth285 Performance and Tech 7 02-25-2009 12:28 PM
Fork seal replacement 2ligitninjas Performance and Tech 20 02-08-2008 08:50 AM
fork seal replacement logmaster Performance and Tech 7 06-11-2007 03:12 PM
