Kit Harness issue - Kawasaki ZX-10R.net
post #1 of 9 Old 03-17-2013, 06:49 PM Thread Starter
GODSPEED's Avatar
Kit Harness issue
So- I have my hybrid 2011+ ZX10 with a Kit Harness where I cannot find any plug ins for the Throttlebodies or coolant temp sensor, along with a few other minor issues. Everything is brand new, has anyone installed one yet? I have the kit manual but nothing in there about this. Hence, I cannot start the thing.
GODSPEED is offline
post #2 of 9 Old 03-17-2013, 07:58 PM
badassjake's Avatar
an extra sub harness missing?
badassjake is offline
post #3 of 9 Old 03-17-2013, 08:54 PM Thread Starter
GODSPEED's Avatar
thats what i am trying to find out, for sure there is not kit parts i am missing tho, and its never been a streetbike so there are zero stock parts on the bike...
GODSPEED is offline
post #4 of 9 Old 03-18-2013, 07:36 AM
kman0066's Avatar
Which plug-ins on the throttle bodies are you referring to? Secondary motor, TPS sensors? Those should all definitely have connectors on the harness somewhere. There is also definitely a coolant sensor plug on the harness as well. Assuming you have the correct harness, the plugs are on that harness somewhere. You should be able to fully install the kit ECU with just the kit harness and the fuel pump relay. The kit manual has a wiring diagram in it that tells you the color of the wires going to each plug which should help in narrowing down which plug goes where. Just go through each left-over plug until you find the one you need for each connection. There will be a few left over plugs in the end though for the interface box, quick-shifter, etc.
How long did it take to get your ECU & Harness after you ordered them? I'm waiting on back-order from Kawasaki for my harness, so I haven't got the chance to install it yet actually...
WERA Expert #43
2012 WERA National Challenge Series Open Superstock Novice Champion
http://maps.wera.com/racers/racerpro...30532136163864
COMET RACING LEATHERS
2011 ZX-10R Race bike (Vortex, Silkolene, Leatt, Yoshimura, BRIDGESTONE)
2013 ZX-6R 636 Race bike
2008 Ducati Hypermotard 1100s
kman0066 is offline
post #5 of 9 Old 03-18-2013, 10:29 AM Thread Starter
GODSPEED's Avatar
I will take pictures of the deal later today.
I got the Harness and ECU with 4 days.
GODSPEED is offline
post #6 of 9 Old 04-09-2013, 11:21 AM
I have the kit ecu and kit harness, kit manual for a 2012 zx10r.
No problems with the install, nothing extra needed.
Good luck!
JasonG is offline
post #7 of 9 Old 04-09-2013, 05:21 PM Thread Starter
GODSPEED's Avatar
ACTUALLY there "IS" a sub-harness! After 2 months of the same answer Jason Farrell contacted me and let me know there is a sub-harness and provided the part #. (dont have it on hand) It has the TPS plugs, the coolant temp sensor plug and 1 that plugs into the main harness. the casing around the wires is grey in color. The wiring runs under the Throttlebody between the #3 and 4 cylinder. I hope this helps somebody in the future that trys this build, should someone want to try it!
After that,as of today I was finally able to fire the 10R up for the first time today!
GODSPEED is offline
post #8 of 9 Old 04-10-2013, 06:59 AM
kman0066's Avatar
Huh, guess it's a stock part. Didn't think about how you might need some parts like that since you're building from scratch. If you start off with a stock bike, then you don't have to buy the extra sub-harness to change over to the kit harness/ECU.
WERA Expert #43
kman0066 is offline
post #9 of 9 Old 04-10-2013, 09:07 PM Thread Starter
GODSPEED's Avatar
Right. The fact that this is from scratch was what I was stressing, as I knew for a fact no sub-harness existed as far as Kit parts, but was desperately looking for an answer from the stock parts- as it was specific to the TPS sensors. Once I got the picture another guy sent me of his TPS I knew there another harness because of the color the covering the wires wasnt black!
GODSPEED is offline
Gen 4: kit ECU harness Older Guy The ZX-10R 0 09-12-2011 05:20 PM
Gen 4: Factory Kit Race Parts :Akrapovic. Kit Harness & ECU Bevan175 Parts, Gear and Accessories 0 06-28-2011 01:58 PM
08-10 Kit ecu Sub-harness johnnyb-21 Parts, Gear and Accessories 0 03-10-2010 03:56 PM
08-09 Kit ECU and Harness johnnyb-21 Parts, Gear and Accessories 10 12-06-2009 09:03 AM
Kit ECU and Harness 10R Parts, Gear and Accessories 7 08-20-2008 03:20 PM
