Gen 2: 2006-2007 Killswitch - Kawasaki ZX-10R.net
post #1 of 7 Old 07-15-2018, 07:10 PM Thread Starter
manuelhung's Avatar
Killswitch
I was out on my gen2 hitting some twisties today and on a very bumpy straight I went to pass a car. As I passed the car the throttle went dead, I couldn't shift up and the FI light was flashing. I shifted down through the gears, pulled over and shut off the ignition. As I took off my gloves and helmet I noticed the killswitch was in the off position.
I didn't hit the switch myself so how the hell did it happen??? Could an extremely bumpy road trigger the switch? Is there some sort of failsafe that triggers the killswitch to avoid some sort of catastrophic failure? Some sort of electrical problem? Or a freak occurance?
Any info would be appreciated.
manuelhung is offline
post #2 of 7 Old 07-16-2018, 01:31 AM
evilaugust's Avatar
Don't know man. I quit dicking about with that thing a long time ago. Two many scary situations, accidental whoolies, etc. Once you bounce your nads off the tank at 80 MPH, you go home and disconnect.
evilaugust is offline
post #3 of 7 Old 07-16-2018, 03:21 AM
spray____'s Avatar
It's just a simple switch. On closes the circuit, off breaks it. Either you bumped it without noticing, or the vibrations were enough to shift to the off position. I would expect there is a spring inside that holds it to the end of it's range of motion after it's toggled. Maybe the spring is wearing out. Does it click firmly into place and stay there after you've pressed it?
spray____ is offline
post #4 of 7 Old 07-16-2018, 09:03 PM
evilaugust's Avatar
Simple, like, cut, connect, done. Just don't ride off with your kick stand down and pole vault yourself on a left turn.
post #5 of 7 Old 07-17-2018, 02:54 AM
spray____'s Avatar
I think he's talking about the killswitch, not the sidestand switch.
post #6 of 7 Old 07-17-2018, 06:55 AM
evilaugust's Avatar
In that case, I'm going to say he hit it. It's a pretty stiff mechanical switch.
post #7 of 7 Old 07-17-2018, 08:02 AM
NinjaLife's Avatar
I've hit mine on accident while stopping to get gas, I'm betting it was accidentally pressed too.
Only way to tell for sure is to check the switch, make sure it operates normally, then maybe go back on a test ride take to see if you can re-create what happened.
NinjaLife is online now
ignition to killswitch ninja10kid Performance and Tech 0 05-20-2012 01:16 PM
imobilizer killswitch mrdrink Performance and Tech 5 02-17-2010 11:12 AM
Killswitch for Drag Racing MotoTech10R Wanted: Buy or Trade 7 10-28-2008 12:01 AM
