kawasaki head stem bearings or aftemarket? - Kawasaki ZX-10R.net
post #1 of 8 Old 09-30-2010, 09:22 AM Thread Starter
Hi everybody
2004 ZX-10 owner.
I did make my search but i could not find a clear answer.
Strangely,in my opinion,after 10000miles the head bearings need replacement.
I can feel a click when braking but more importantly there is "stopping"gap just in the middle between far left and far right.Trying to fix the clicking makes the gap worse.
My current mechanic says to use the original kawi items but others saying that aftermarket is ok.The difference in price is the double against the kawi.
What to you think?
(I have to mention that the bearings right now are NOT the Kawi ones,the original lasted for 30000miles,i went for aftermarket and now they need replacement,but i am suspicious that the previous mechanic did not did the work properly,as i am driving the same roads ,the same style and speed.
Finally ,who is following the whole procedure as the manual says?)
THANK YOU
K.makry is offline
post #2 of 8 Old 09-30-2010, 09:46 AM
RDLYN13000's Avatar
Images: 38
Go with allballz tapered bearings, there about $35 bucks...
RDLYN13000 is offline
post #3 of 8 Old 09-30-2010, 09:47 AM
09zx10miami's Avatar
I use allballs racing bearings ..... They are definitely a upgrade to the factory bearings......
09zx10miami is offline
post #4 of 8 Old 09-30-2010, 09:54 AM
RDLYN13000's Avatar
Images: 38
Here's a link... I would check out our site sponsor 303 cycle there a bit cheaper...
https://www.allballsracing.com/index.php/22-1039.html
post #5 of 8 Old 10-02-2010, 01:48 PM Thread Starter
Thanks a lot but unfortunately but i will have to settle for KOYO(made in japan),because i cannot find these in Europe.
K.makry is offline
post #6 of 8 Old 10-02-2010, 01:50 PM Thread Starter
Thank you for the information but allballsracing are not easy to find in Greece-Europe so i will buy KOYO.
K.makry is offline
post #7 of 8 Old 10-02-2010, 01:51 PM Thread Starter
Thanks a lot!!
K.makry is offline
post #8 of 8 Old 10-13-2010, 11:48 PM
bugman53's Avatar
I have had races crack on the allballz brand installing but never with the oems. I like the oems better IMO.
bugman53 is offline
Steering Stem Head Nut BADNCO The ZX-10R 7 06-28-2010 12:31 AM
adjusting steering stem bearings logmaster Performance and Tech 9 02-23-2008 02:41 PM
Kawasaki OEM Head Stem Spanner Wrench**SOLD** ghostrank Parts, Gear and Accessories 12 03-27-2007 07:03 PM
2005 forks, steering stem, bearings, axle - perfect JLove Parts, Gear and Accessories 1 03-11-2007 11:40 PM
steering stem bearings and kawa CDI tuning Riceburner The ZX-10R 10 06-12-2005 01:40 AM
