K&N filter OUTTA there! - Kawasaki ZX-10R.net
post #1 of 21 Old 05-24-2007, 02:27 PM Thread Starter
Supercharged Mod
Looks like the K&N filter plugged up AGAIN ... I'm back to stock, sick of fiddling with this thing. I know you can clean them, but having to do it every oil change ... ! ? !
Background. Stock filter was in there until first major service at 23,000 km and never caused any trouble. I got talked into a K&N filter for the usual reasons. Around 8,000 km later, I started noticing a drop-off in top end power, and after a little bit more time to figure out what the problem was, I determined that the filter was clogged (around 32,000 km). I cleaned it and put it back in. Now, around 37,000 km, the drop-off in top-end power started happening again - first noticed it last night. Today I bought a stock air filter and that's what's in there now. The K&N doesn't look *quite* as dirty as it did last time around, but last time it took a bit of time to figure out what the problem was.
Why do they clog so fast? We have a lot of bugs and sandy roads around here, which doesn't help, particularly at this time of year. But also, before putting the stock filter in, I did a little comparison.
The K&N filter has 23 pleats, counting from one side to the other. The stocker has 67. And the depth of the pleats on the stocker is at least a third deeper. The stock filter has 4 times as much filter element area ... Granted, a lot of the stock pleats are so close together that air might have a tough time getting in between, but still.
No test ride yet ... changing the filter was a one-beer job, and we don't ride for a wee bit after that!
GoFaster is offline
post #2 of 21 Old 05-24-2007, 02:42 PM
BMC all the way sucka !!!!!!
fordfasterr is offline
post #3 of 21 Old 05-24-2007, 02:47 PM
Images: 7
BMC race filter
shenanigans is offline
post #4 of 21 Old 05-24-2007, 02:54 PM Thread Starter
Supercharged Mod
How many pleats side to side, and what's the depth of the filter element?
GoFaster is offline
post #5 of 21 Old 05-24-2007, 03:17 PM
Still here
ZX10Miami's Avatar
Used k&n since I was a kid iback n my dirtbike days. Also in my old mustang and even one in the 10r right now- got it (k&n) cheap.
Having said that-
The BMC does look to be a better piece. The design is much closer to the stock plastic filter housing rather than the k&n slip in, blade type design.
BMC probably does have deeper pleats like stock.
Not sure about using the race version on dusty nasty roads but the street version, just to be able to clean it, might be worth a look.
ZX10Miami is offline
post #6 of 21 Old 05-24-2007, 03:30 PM
If changing the filter is only a one beer job what is the issue?
If the filter is gunking up
Its not letting all that dust bugs into the motor
Doing its job.
Are you using too much oil? You do not saturate the filter. You oil it and let the oil soak into the rest of the cloth. I have never had any problems of this sort with KN on any bike or car.
Granted i think the power gains are over exagerated but the re-use is nice.
06450F is offline
post #7 of 21 Old 05-24-2007, 03:40 PM
Rspec99's Avatar
Images: 11
I have a K&N in mine and I haven't had any problems and although I know some here have complained about it, the fit is nice and snug on mine. It has done a great job in filtering the incoming air as the area before the filter is dusty with dead bugs and other debris. The inside of the airbox after the filter is squeaky clean. I also have a BMC race filter for my R1, and am also very pleased with it. The quality between the two are very close, but I'd probably buy BMC over K&N, primarily because the sides surrounding the filter element feel a little sturdier.
I can't imagine that the filter could be so saturated with dirt that it would in effect choke the engine of high rpm horsepower that it could be felt from the rider's seat. Let us know if the stock filter improves the situation. The K&N in my S2000 is almost black after 50,000 miles and it still pulls cleanly on top. I am just too lazy to work on the car with my bike projects.
Rspec99 is offline
post #8 of 21 Old 05-24-2007, 04:06 PM
Additionally I think top end may be the area least effected as the air is "blasted" with force. Seems low end would suffer from lack of pressure due to no air.
If your KN is backed up with bugs, a OEM will catch them just the same and plug up with bugs and dirt........if it don't plug up then its allowing the dirt into the motor.........plug up is good!!!
06450F is offline
post #9 of 21 Old 05-24-2007, 04:07 PM
K7ZX10RGuy's Avatar
Send a message via AIM to K7ZX10RGuy
A friend of mine works for K&N and got me the filter for my '07 10R for just $20. Although, I was pleased with the price, I wasn't really pleased with the quality of fit. The Stocker is a nice peice and if the BMC has a frame like the stocker, I will be buying one when this K&N cloggs up
"Better to remain silent and be thought a fool than to speak out and remove all doubt." -- Abraham Lincoln
A clear conscience is usually the sign of a bad memory.
K7ZX10RGuy is offline
post #10 of 21 Old 05-24-2007, 04:24 PM Thread Starter
Supercharged Mod
That's true, but with 4 times as much area of the filter element, the stocker will take that much longer before it's buggered, and it will probably have less pressure drop than the K&N through most of its useful life, after the K&N has even slight dirt loading on it.
Part of the problem is this specific application. The ZX10R filter has very little "frontal area" considering the power of the engine (which is practically in direct proportion to the amount of air it draws in). I had a K&N filter in my previous car, too, and it never caused problems, but that filter was probably 5 times more filtering area for an engine with less power than this one!!
The comment about part load operation being affected might be true. I've noticed for the last couple weeks that something wasn't quite right but I couldn't put my finger on it until yesterday. I'm going out for a ride tonight; that should confirm whether this was the real problem ...
GoFaster is offline
1st oil change outta the way, its on now... greeniner The ZX-10R 16 05-14-2007 03:12 PM
I'm outta here. YSR50 The Out House 25 03-23-2007 05:50 AM
i'm outta here for a few months bradshow01 The Out House 12 02-16-2007 10:34 PM
Just outta Curiousity... peejay The Out House 5 01-13-2006 06:52 PM
Slide slides outta here slide The ZX-10R 4 05-18-2005 07:51 PM
