Just mounted Q2's on my friends '03 636, steering effort VERY high now =( - Kawasaki ZX-10R.net
post #1 of 5 Old 08-27-2010, 01:19 AM Thread Starter
speedgsx98's Avatar
Not sure what's up, but feels like I'm countersteering VERY hard just to get the thing to turn, then it just wants to fall. Then I have to countersteer back the other way to keep it from falling in too quick. Anyone else have issues with the Q2's turn in?
Keep in mind I went from a 120/65/17 stock to a 120/70/17. Kept the 180/55/17 size mounted on the rear. Rode it, and felt like poo, so dropped the forks about 8mm and took it back out and still felt like poo. Not getting it! A larger front tire would normally make it turn slower with more rake, but dropping the forks should have remedied that.
speedgsx98 is offline
post #2 of 5 Old 08-27-2010, 01:30 AM
PJD
PJD's Avatar
I think you dropped the forks too much.
PJD is offline
post #3 of 5 Old 08-27-2010, 03:54 AM
jdgun_13's Avatar
Send a message via Yahoo to jdgun_13
the 120/65 to 120/70 swap will honestly make about ZERO handling difference from what i have experienced on riding the 03-06 zx6r..
The 1st question you have to ask yourself is, what brand tire did you have on before?
what is the shape of the tire (total circumfrence front & rear)?
was the bike set-up for this specific tire, raised rear/front dropped front/rear?
have you measured the front rake of the bike?
8mm drop in the front end is a pretty noticeable difference, for just the swap i would not have changed anything just rode it, then adjusted from there.
Now taking into consideration of the tires charecteristics, this 8mm drop and the qualifier shape, you may have this drop in feeling....ride some pirelli super corsa's or other race type tires and they are built for corners not cruising around the block, so the drop in is totally normal.
try getting the bike back to stock ride height, check your sag, measure your rake and then adjust from there...typically i rather raise the rear end up a few mm before dropping the forks, or do a bit of both to get the desired effect...
jdgun_13 is offline
post #4 of 5 Old 08-27-2010, 09:52 AM Thread Starter
speedgsx98's Avatar
I didn't drop the front initially. I test rode it after mounting the tires, and it felt like such crap that I then decided to drop it a fair amount so I could tell a difference. Really didn't notice anyimprovement after dropping it either.
Problem is I rode the bike once several months ago, so I'm comparing it to my '08 10R, but I don't remember it feeling hard to steer then. Riding my 10r just after riding the 636 with the new tires...it felt much eaasier to turn thatn the 636.
I used to have a 2002 GSXR 1000 a few months back and when I would go back and forth between those 2 bikes, the difference in steering effort was nigh/day. I think I need to get my friends bike(the 636) back and ride it again. I used to work on motorcycles for a living. I'll try loosening the axle and retightening in case something is binding...that's all I can think. I'll prob raise the front back up some too.
Maybe the profile of the tires is just funky though? I know new tires don't feel as twitchy as older tires because of the perfect profile when new. They don't tip into the lean as easy. Strange =(
post #5 of 5 Old 08-28-2010, 03:18 AM
jdgun_13's Avatar
Somewhere along the way you totally threw off the whole geometery of the bike.
The swap from a 120/65 to a 120/70 is not even noticable to 99% of riders.
take it to someone who can set your suspension up for you, as obviously didnt do anything in the last line i put to get the bike sorted...start from a base and work from there.
that 636 you have is a damn scalpel and should take almost no effort to get it to do what you want.
jdgun_13 is offline
FT-Scotts steering damper/Micron CF high mount Slip on I_RUN Parts, Gear and Accessories 4 07-06-2010 02:47 PM
Spies getting a Bike for his effort? jdgun_13 Race and Stunt 15 10-28-2009 10:43 PM
When friends let friends ride their zx10r duacatijay The ZX-10R 97 01-03-2008 02:53 PM
Boeing/Kawi joint effort? El Diablo Pictures and Videos 30 02-16-2005 05:52 AM
Kawi's Formula Extreme Effort in '05 kawiman88 Race and Stunt 14 12-05-2004 04:58 PM
