Just installed PCIII and Im getting a constant 100 TPS reading.. - Kawasaki ZX-10R.net
post #1 of 6 Old 08-05-2007, 03:52 PM Thread Starter
Rock_Star's Avatar
I have taken it apart 3 times to check the TPS wires, and they are plugged in tight.
I have loaded a few different maps, and the bike generally revs good (on stands) but it will not idle. When I try to let it idle, it dies but I can rev it to keep it alive.
I dont think its a map issue -maybe a wire problem or I damaged my TPS???
Any thoughts?
I searched around for a while and found a old thread about the "rough idle update" but I dont think it applies b/c the post was back in 04.
ANd I didnt see anything on pc website about this...
Thanks,
Andrew
Rock_Star is offline
post #2 of 6 Old 08-05-2007, 04:28 PM
FAF
Rent this space
Did you reset the TPS with the PC111 ?
Also dif you get the PC111 connected to the right plug, it is easy to get it wrong, as the grey and the brown plug are the same.
FAF is offline
post #3 of 6 Old 08-05-2007, 05:51 PM Thread Starter
Rock_Star's Avatar
plugs look good.
How you reset the TPS?
post #4 of 6 Old 08-05-2007, 06:18 PM Thread Starter
Rock_Star's Avatar
did a search and was able to reset the TPS.
I also, cleaned out the connectors really well- nd the bike idled normal...
I dont know which it was but im happy...
THANKS!!
post #5 of 6 Old 08-05-2007, 08:43 PM
themightymezzo's Avatar
What was the thread where you reset the TPS in case I have to do it when mine comes?
Thanks.
"You can't trust anyone, not even your own asshole; sometimes you think you're gonna fart and you sh*t."
themightymezzo is offline
post #6 of 6 Old 08-06-2007, 10:37 AM Thread Starter
Rock_Star's Avatar
Thanks.
i got it on the pc website under troubleshooting...
Q. FI light came on after PCIII was installed michboy Performance and Tech 8 12-13-2006 09:40 PM
Idle won't stay constant. 1killer1liter Performance and Tech 18 06-20-2006 10:42 AM
My 05 ZX10R needs constant throttle play adjustments MadHatter Performance and Tech 9 05-12-2006 12:40 PM
PCIII,T.R.E. Installed............... R1GSXRKILLER Pictures and Videos 3 03-20-2005 08:47 PM
UPDATED WITH PICS - Installed a Full Akra, TRE and PCIII JLove The ZX-10R 48 03-03-2005 12:29 PM
