Gen 1: 2004-2005 jumping out of gear? - Kawasaki ZX-10R.net
post #1 of 29 Old 09-26-2012, 10:23 PM Thread Starter
tone.r's Avatar
Im lost with this i was at the track last weekend and my bike was jumping to neutral, I was geared 17\47 but when i put my 16\45 back on it dont do it.
I was street riding and it never jumped out of gear not one time, I started in 1st to 6th gear didnt jump out not one time
tone.r is offline
post #2 of 29 Old 09-26-2012, 11:17 PM
BigCat for Prez!
BigCat10R's Avatar
Gun it and see if it does it. When it jumps back into neutral from 2nd like that it means ur transmission is going
BigCat10R is offline
post #3 of 29 Old 09-27-2012, 01:18 AM
Geordie's Avatar
My Gen 2 is starting to do this, not very often though. Normally when i gun it in first, clutchless shift into 2nd, then gun it again. It picks up, then drops out, making me bounce the limiter in neutral.....
And its normally when warming up (not from cold though, after a slow ride out the streets onto the highway, and after warming up on the driveway til the temp starts reading more then 50deg Celsius.)
Doesnt happen everytime. And when powering on in 2nd, It doesnt happen. Just when shifting from 1st to 2nd. With or without the clutch. You reckon thats the transmission too? Is it gonna be an expensive repair/replace? or is it game over for the bike?
Geordie is offline
post #4 of 29 Old 09-27-2012, 01:27 AM
BigCat for Prez!
BigCat10R's Avatar
Its not game over for the bike, but it will be expensive if a shop does it. It sounds like the dog legs in the gear are wearing down and its causing it to pop out
post #5 of 29 Old 09-27-2012, 02:31 PM
evallarta1's Avatar
As BigCat said your transmission may be going out. One other CHEAP thing to try first is adjust your shift lever down a little bit. You might be doing lazy shifts and the gears arent engaging all the way and popping out. I had this issue with my Gen 1 and adjusting the shifter eliminated the problem.
evallarta1 is offline
post #6 of 29 Old 09-27-2012, 02:36 PM
BigCat for Prez!
BigCat10R's Avatar
Yea if u lazy shift and aren't engaging the gears all the way it'll wear the dog legs out and then it will wear them down too much and itll never full engage and will always pop out
post #7 of 29 Old 09-30-2012, 09:48 AM Thread Starter
tone.r's Avatar
I did just play with my ajustments i just done my tranny last year its not that hard of a job if you dont mind working on your bike.
tone.r is offline
post #8 of 29 Old 09-30-2012, 01:52 PM
badassjake's Avatar
GP shift for drag racing eliminates all the lazy shifts.....I may never go back to conventional shifing again
badassjake is offline
post #9 of 29 Old 11-02-2012, 12:08 PM
SpOoNpR's Avatar
im having this same issue on my bike .. i adjusted the shifter lower and it still jump it's driving me crazy.. i got a used tranny from ebay waiting for it on the mail to change it... i was wondering when i do open the motor to change the tranny is there something in particular i should be looking for in the gears to make sure thats were the problem is?
SpOoNpR is offline
post #10 of 29 Old 11-02-2012, 12:17 PM
Slow Poke
bgmagma10's Avatar
When you look at your gears start with first which is the biggest gear and should be fine. Look at the next gear on the shaft which is 2nd. There are windows in the middle of the gear. To the left and right side of the window is where the dogs catch the gear when you shift. When the edges are kind of rounded off that's why it will jump out of gear. It should be a straight edge. But if its bad you will be able to see the marks of where it's rounded off.
bgmagma10 is offline
Jumping Ship LTChris The Out House 15 04-08-2011 03:42 PM
Jumping while racing gomer Pictures and Videos 3 09-08-2010 02:22 AM
Bungee Jumping 06BLK10R The Funny Pages 11 01-23-2008 10:18 PM
jumping out of gear mikebar4 Race and Stunt 5 04-12-2006 07:42 AM
Need Help Jumping Bike modiggs Performance and Tech 11 04-15-2005 01:33 AM
