Ivan's ZX10 performance..... - Kawasaki ZX-10R.net
post #1 of 71 Old 01-31-2005, 01:59 PM Thread Starter
ivansperformanceproducts.com
Ivan is offline
post #2 of 71 Old 01-31-2005, 02:06 PM Thread Starter
Ivan is offline
post #3 of 71 Old 01-31-2005, 03:18 PM
ballsup's Avatar
what are the settings on the cams if you dont mind telling
ballsup is offline
post #4 of 71 Old 01-31-2005, 03:30 PM
MIA Post Whore
miykl's Avatar
from another thread:
Originally Posted by Ivan
When I am ready to share them, I will....
I want to be sure that the gains are real, and that can only be verifyed by some on the road testing.... (too much snow right now)
I don't want people to set their cams to something that is not 100% proven yet.
STD correction factor...
My dyno is a model 200 (reads 7% lower than a model 250)
These #'s were gotten in 65 degrees and low humidity.
I'll post a chart soon.....
Ivan
miykl is offline
post #5 of 71 Old 01-31-2005, 04:04 PM
Supercharged Mod
Mighty impressive numbers. I gather there's a PowerCommander in there?
So for chart number 4, the only change was putting the ignition timing back to stock? If that's the case, it looks like changing the ignition timing doesn't do much unless one has the thin head gasket and has changed the cam timing and then it really does something.
Chart number 5 must be stock versus final result with the Akra.
I don't wanna make noise and attract attention ... more interested in midrange torque than peak HP in my case ... Thin head gasket, re-degreed cams, timing advance, and P-C but with the stock exhaust system is starting to look interesting ...
GoFaster is offline
post #6 of 71 Old 01-31-2005, 04:30 PM
kawiralph's Avatar
Always impressed by the way you take your time and investigate what to do to a bike to maximise it's performance.
Keep up the good work!
Ralph
Only green is really mean! 1984 GPZ 900R & 2004 ZX10R => 20 years of NINJA power
kawiralph is offline
post #7 of 71 Old 01-31-2005, 05:39 PM Thread Starter
Ivan is offline
post #8 of 71 Old 01-31-2005, 06:27 PM
Big Daddy's Avatar
Images: 38
Awesome work Ivan.
Big Daddy is offline
post #9 of 71 Old 01-31-2005, 06:36 PM
ballsup's Avatar
thanks Ivan
ballsup is offline
post #10 of 71 Old 01-31-2005, 07:38 PM
Certified SLOW
nolaZX10's Avatar
good info, keep up the good work
nolaZX10 is offline
Doug Polen (fmr WSBK #1) tests the ZX10 zeta xray The ZX-10R 11 12-15-2004 01:58 PM
Ivan's Holiday Prices on Akrapovic Full systems and Slip-ons Ivan Vendors deals 0 12-09-2004 05:32 PM
01 R1 vs 04 ZX10 For Sparko (long post!) Vaeban The ZX-10R 22 12-03-2004 07:41 AM
My first ZX10 track day zeta xray The ZX-10R 31 04-12-2004 05:46 PM
04 R1 vs. 04 zx10 GP415 The ZX-10R 41 04-07-2004 06:11 PM
