Ivan's TRE question - Kawasaki ZX-10R.net
post #1 of 15 Old 04-03-2009, 06:30 AM Thread Starter
Oengus's Avatar
Ivan's TRE question
hi guys
sorry about the stupid question, maybe you have discussed it before or maybe I haven't understood how it works
does it unblock the 299km/h limits on the speedometer ?
I've mounted it and removed secondaries.
Tomorrow I'll test the bike on the track
Oengus is offline
post #2 of 15 Old 04-03-2009, 07:22 AM
sextaafondo's Avatar
:headshake
Not at all.
sextaafondo is offline
post #3 of 15 Old 04-03-2009, 01:16 PM
I just put the TRE on my 07...I have read all the other posts, and I still dont understand what it does myself. Also, I dont think the bike drives an different. I have no before after dyno results, but the seat of the pants dyno says there is no difference
10r_rider is offline
post #4 of 15 Old 04-03-2009, 02:04 PM
Rhyan_vosburgzx-10's Avatar
Send a message via Yahoo to Rhyan_vosburgzx-10
TRE Timing Retard Eliminator. In the first 4 gears of at least the 06 and 07 the timing is retarded to TRY to keep the front wheel on the ground. This means you dont get FULL power untill 5th gear. The TRE gets rid of this timing retard and you can get full power in the first four. does not do a thing for top end or the 186mph or 299kph top end.
Rhyan_vosburgzx-10 is offline
post #5 of 15 Old 04-03-2009, 06:53 PM
The TRE only addresses partial throttle in the first 4 gears. It is very noticeable at 1/4 to 1/2 throttle. Does nothing at full throttle. Also eliminates the fuel shutoff when the throttle is closed.
Visit Ivan's site. He has a pretty good write up. Been cover here thousands of times, but there is often misinformation given.
TN10R is offline
post #6 of 15 Old 04-05-2009, 09:02 AM Thread Starter
Oengus's Avatar
I'm quite disappointed
yesterday I tested the bike on the track after having removed the 2ndaries and installed the Ivan's TRE
I hoped to have a smoother throttle. The result was, the on/off in not eliminated
when I open the throttle after a bend, the bike is more nervous and difficult to drive...
Oengus is offline
post #7 of 15 Old 04-05-2009, 12:43 PM
can not verify that. i have removed the seconderies plus a TRE from Healtech.
Throttle response is much better now and bike is easier to control.
Peli67 is offline
post #8 of 15 Old 04-05-2009, 04:17 PM
Put a speedo healer on the bike. That´ll fix the 299km/h problem, as you´ll never pass 299km/h
Atleast if you calibrate it correctly.
espen is offline
post #9 of 15 Old 04-05-2009, 07:49 PM
edouble's Avatar
The only reason I want an Ivans TRE is because it eliminates the factory full cut off at 0% throttle. This is suppose to help the bike spool up when you go back onto the throttle.
edouble is offline
post #10 of 15 Old 04-05-2009, 08:01 PM
ZX-10R_Sinner's Avatar
Exxxaaactly, I have my flies pulled and it doesn't bother me but I'm not a track day rider, if I was I could see where that jerkiness might be a problem.
You won't really notice that jerkiness though if you're always on the throttle.
ZX-10R_Sinner is offline
Ivan's TRE module and Ivan's Air Pump Block Off Plates PumpinIron Parts, Gear and Accessories 1 12-10-2008 11:24 PM
FS: Ivan's TRE ZX10man Parts, Gear and Accessories 5 05-05-2006 10:53 PM
IVAN's TRE jarhead05 Performance and Tech 3 04-13-2006 04:34 PM
Ivan's TRE DB's ZX10R Performance and Tech 7 06-20-2005 10:53 AM
Ivan's TRE Rubber Pants The ZX-10R 3 04-06-2005 12:31 AM
