ivans tre install on an 06 - Kawasaki ZX-10R.net
post #1 of 19 Old 09-03-2010, 09:09 PM Thread Starter
codyc_13's Avatar
Hey guys I hate to create a new thread on this but for some reason the search won't work on my blackberry.. I need to know exactly which wires I need to pull out of the plug and what plug is it? Thanks a lot guys
codyc_13 is offline
post #2 of 19 Old 09-03-2010, 09:52 PM
BANNED
Try this, I have it, it works as advertised.
MagicMavis is offline
post #3 of 19 Old 09-03-2010, 09:56 PM Thread Starter
codyc_13's Avatar
Sweet thanks a lot magic
codyc_13 is offline
post #4 of 19 Old 09-03-2010, 09:57 PM
BANNED
GPS (Gray Connector) can be hard to separate. It has 2 latches. Pry down and keep one latch open using a small screwdriver as shown in the pic. This is the actual connector you will be working with.
Use your thumb to depress and hold the second latch, and pull HARD. It will come apart then.
Otherwise, WITHOUT using the screwdriver it is hard to depress both latches at the same time and seperate the connector.
ID:	135481   Click image for larger version
ID:	135482   Click image for larger version
post #5 of 19 Old 09-04-2010, 12:00 AM Thread Starter
codyc_13's Avatar
Well the tre was a breeze took about 10 minutes, BUT while I was in there I decided to remove the secondary flies and on one of the flies the head od the screw completely broke off leaving the actual screw in the tap. The fly still came off just leaving the screw in the hole with the head gone...my ? Is, will it be ok to just leave it in there. It doesn't seem like it can go anywhere
codyc_13 is offline
post #6 of 19 Old 09-04-2010, 12:36 AM
den33's Avatar
Installing a TRE on my 08 this weekend hopefully. Damn mail and holiday weekend! How is it? Improved throttle response?
den33 is offline
post #7 of 19 Old 09-04-2010, 01:08 AM Thread Starter
codyc_13's Avatar
I haven't rode it yet, I have a pc3 coming next week so I'm just going to leave it apart until then...the hardest part about the install is getting the actual pins out of the plug you have to push them over and pull out at the same time...it hard to explain but if you have to force them out you are doing it wrong.
codyc_13 is offline
post #8 of 19 Old 09-04-2010, 01:55 AM
den33's Avatar
Damn layin the bike up for the weekend?lol: I'm hopefully getting my pc3 and ivans tre in the mail tomorrow. Cant wait, Ivan swears by the tre, and on the gen 3 it disables the KIMS. We'll see soon I guess. Good luck
den33 is offline
post #9 of 19 Old 09-04-2010, 08:05 PM Thread Starter
codyc_13's Avatar
Anybody know if that screw will be ok
codyc_13 is offline
post #10 of 19 Old 09-04-2010, 10:20 PM
mechmain's Avatar
If that happened to me, I would get some wicking loc-tite, I think its the green one and put a drop or so on it and let it cure for about 24hrs.
Or you can take that part of the intake off and try and drill it out
mechmain is offline
2008-09 10R install help! IVANS TRE mainevent Performance and Tech 7 10-23-2009 09:58 PM
Ivans TRE Map Big Poppah The ZX-10R 35 04-21-2009 03:30 AM
ivans tre bodyglove Performance and Tech 3 12-06-2007 10:34 AM
Ivans TRE for 06, a must have! CBRE The ZX-10R 19 06-09-2006 11:52 AM
Euro Install: Easiest Way to Re-install Inner Liner Under Headlight? IcePick06 Performance and Tech 18 12-30-2005 11:52 PM
