Ivan's TRE
Ok.....got it in finally and installed my PCIII and K&N air filter at the same time. And yes, I did the sub throttle sensor adjustment (holy crap, what a biotch to loosen the T25 security torx bolts). Ivan also sent me a map for the set-up that I have....Akro slip-on, PCIII, TRE, K&N Air filter. I put everything back together after double checking install and started her up......fricken' FI light is on! I take all the crap off and check the wiring again......looks good. Put everything back (and for good measure, I dis-connected the battery for a few minutes to see if FI will go off after turning it back on) and start her up......FI light still on. I then take it for a test ride with the FI light on. The bike runs like crap.......bogs down at about 6K rpm in all gears and sounds/feels like it is going to die down.
I have read a zillion pages in here about different TRE topics and did not find an answer.....
Anyone have any ideas on what my problem could be? (besides the smart ass "you installed it wrong, dumbass".)
Thanks!
DB
Thanks!
DB
