IVAN's TRE - Kawasaki ZX-10R.net
post #1 of 4 Old 04-13-2006, 10:00 AM Thread Starter
jarhead05's Avatar
IVAN's TRE
I have a question for you wonderful folks. I put on the TRE on my 04' ZX-10R, AKRA slip on and a K&N air filter, and power commander. The guy that is dynoing my bike is having problems in the first 4 gears, spikes on 10-40% throttle in those gears. 5-6 are fine. I turned the throttle position sensor and readjusted the throttle like I was suppose to and everything was good. I am out here in PA and he is only getting 150 hp out of it on the dyno. Something is wrong here!!! Any suggestions? I know the TRE effects the first 4 but it was suppose to be smoother, not spikey. That is what he is telling me the bike is doing anyway. If he does a normal highway run on the dyno, the bike is fine though. HELP ME!!!
Marines I see as two breeds, Rottweilers or Dobermans, because Marines come in two varieties, big and mean, or skinny and mean. They're aggressive on the attack and tenacious on the defense. They've got really short hair and always go for the throat.
-RAdm "Jay" R. Stark, USN, 10 Nov. 1995
jarhead05 is offline
post #2 of 4 Old 04-13-2006, 10:22 AM
RickRoush03's Avatar
honestly, call Ivan, he will work with you. you #'s are a tad low, but then again, it all depends on the weather, dyno machine, etc. Also, your PC3, which tune are you usuing, Ivan's, custom, or from PC3 themself?
"Lead, Follow, or get the hell outta my way!!"
Blue 2004 ZX-10R
- 152.5rwhp 77.6rwtq - more than I need
Red 2003 Jack ROUSH Classic #8 of 50
- 375rwhp 381rwtq
RickRoush03 is offline
post #3 of 4 Old 04-13-2006, 10:27 AM Thread Starter
jarhead05's Avatar
I started with the map m212-004 from pc website. He is doing a custom map(trying to atleast), I gave him Ivan's phone #. Hopefully he will call him and he can help.
post #4 of 4 Old 04-13-2006, 03:34 PM Thread Starter
jarhead05's Avatar
I went down and looked at my numbers for my map....really no problems, just a little bouncy on the air/fuel ratio between 3k-6k. Talked to ivan...he said lean it out on the fuel to 12.5-12.8. I will mess with it later.
Ivans TRE and an ignition module or a full exhaust No-Mo Performance and Tech 1 04-05-2006 10:08 PM
Ivan's TRE Retard Eliminator CAZX10R Performance and Tech 14 03-19-2006 03:32 PM
Ivan's TRE DB's ZX10R Performance and Tech 7 06-20-2005 09:53 AM
Ivans TRE LordBadly Parts, Gear and Accessories 5 05-17-2005 10:13 AM
First Ride Impression - TRE, PCIII, Full Akra, Ivan's Map JLove The ZX-10R 17 03-06-2005 10:34 PM
