Ivans Map? - Kawasaki ZX-10R.net
post #1 of 48 Old 04-22-2008, 02:23 AM Thread Starter
tical's Avatar
Ivans Map?
does anyone have the map that ivan provides for the pc3 with his TRE for an 04-05 zx10? if so can you share it please. thanks
tical is offline
post #2 of 48 Old 05-12-2008, 02:18 PM
55delray's Avatar
id like it aswell
55delray is offline
post #3 of 48 Old 05-12-2008, 07:17 PM
phastone's Avatar
No deal. Pay the man for his time and knowledge.
phastone is offline
post #4 of 48 Old 05-12-2008, 07:23 PM
MIA Ex-Mod
Tread70's Avatar
2004 PBO zx10-r pazzo, seat cowl, yoshi Ti TRS bolt on, PC3, Speedo-Healer, Hyperpro, Braided lines, 16-40, Sato sets, ZG dark screen, and more.
Tread70 is offline
post #5 of 48 Old 05-12-2008, 07:53 PM
Its out there just keep looking. In all honesty that map is not "gold'
06450F is offline
post #6 of 48 Old 05-12-2008, 09:03 PM
dirt ninja's Avatar
Images: 9
:iamwithst jk You would be better off using one of dj map. There is no way ivan can give you a good map with all the different exhaust systems out there. Your best bet is to get a custom tune if you can afford it.
dirt ninja is offline
post #7 of 48 Old 05-12-2008, 09:23 PM
SDave2002's Avatar
Far from it.......
FC Suzuki
FC Yamaha
CCS #38
NESBA #38
SDave2002 is offline
post #8 of 48 Old 05-12-2008, 09:42 PM
OneSLOW10's Avatar
Send a message via AIM to OneSLOW10
custom tune brother. Avg price low to high is $150-275
Just spend the money if you got a decent amount of mods. If not mod up then get it done
2005 PMR. Full Ti Evo 2, BMC Race, V-Stacks, PC3, IG Module, DJ QS (not installed), 1/5th throw (not installed), -1 +2 with Gold RK Chain, Speedo Healer V4, Removed 2ndaries, Red GiPro, Pilot Powers, Dual H.I.D.s, Brocks brackets and strap, Rear 2" Muzzy Drop, Vortex Rearsets, Scotts Damper, 2 HyperPro Dampers, Puig DB, ASV Levers, Titax Levers, Pazzo Levers, Kill switch (made to look like it's mounted), CA front/rear lights and a owner who adores her...
OneSLOW10 is offline
post #9 of 48 Old 05-12-2008, 09:56 PM
phastone's Avatar
I love how everyone is an expert tuner.
Didn't say it was "gold". But his maps are among the best there is if a custom tune isn't available to you for whatever reason.
Ivan doesn't have one map he gives out to cover every exhaust. He specializes in Akra but he has other maps for different exhausts/setups. And you are correct about getting a custom tune but the original poster didn't ask whether he should use Ivan's map or get a custom tune.
Originally Posted by Sdave2002
Far from it.......
Like I said. Everyone's an expert. For people who don't know, Ivan has been tuning and developing go fast parts for bikes longer than a lot of people on this forum have been riding or even alive. I wasn't trying to be a dick to the original poster or say that Ivan's maps are better than a custom tune. Ivan doesn't like his maps shared because of all the time he puts in trying to get the most power out of a given combination while keeping good rideability as opposed to just going for big dyno numbers and ending up with a peaky power curve. And I think people should respect his wishes. Besides the fact that if you call and talk to him he will likely give you the map even without buying something from him.
phastone is offline
post #10 of 48 Old 05-13-2008, 06:40 AM
His map is NO better for "your" bike than a provided map by dynojet or any other member who has a map made with the same mods as you. Each bike (motor) is unique. Some maps will work better than other, some will work better upper rpm, some lower.....but his will not fit your bike like it fit the bike it was made for.
If he has you suckered into that thinking, go buy it from him.
Never said i was an expert tuner, but do know what im doing adjusting the FI, and carbs and working with a dyno. A good friend owns a business with one and i have played with it a LOT.
06450F is offline
Ivans TRE HobieZX10 Performance and Tech 4 05-10-2007 06:25 PM
how to buy Ivans tre ??? 1sweetzx Vendors deals 5 03-17-2007 12:21 AM
04-05 Ivans TRE madkaw Parts, Gear and Accessories 3 08-28-2006 12:28 PM
Ivans TRE for 06, a must have! CBRE The ZX-10R 19 06-09-2006 10:52 AM
Ivans For 06 TX06'10r Performance and Tech 1 04-27-2006 08:14 AM
