Ivans Block off help - Kawasaki ZX-10R.net
post #1 of 5 Old 04-25-2008, 12:15 PM Thread Starter
OneSLOW10's Avatar
Send a message via AIM to OneSLOW10
I am currently doing my mods and on the Ivans Block off plates. A 4mm 4.5 and 5mm seem not to be working for me on the oem plates. Anyhelp on how to get them off?
thanks
2005 PMR. Full Ti Evo 2, BMC Race, V-Stacks, PC3, IG Module, DJ QS (not installed), 1/5th throw (not installed), -1 +2 with Gold RK Chain, Speedo Healer V4, Removed 2ndaries, Red GiPro, Pilot Powers, Dual H.I.D.s, Brocks brackets and strap, Rear 2" Muzzy Drop, Vortex Rearsets, Scotts Damper, 2 HyperPro Dampers, Puig DB, ASV Levers, Titax Levers, Pazzo Levers, Kill switch (made to look like it's mounted), CA front/rear lights and a owner who adores her...
OneSLOW10 is offline
post #2 of 5 Old 04-25-2008, 03:53 PM
GrtSaint72's Avatar
i just did mine yesterday i uses either a 5 or 5.5 can be for sure cause i got my air box and tank back on her. but its definatly locktighted in there so it might need some force to break um free.
GrtSaint72 is offline
post #3 of 5 Old 04-25-2008, 05:26 PM
Orange Juice's Avatar
TeamC assisted OneSLOW10 with this mod and we used a 1/4 ratchet and a Torx 30.
Orange Juice is offline
post #4 of 5 Old 04-26-2008, 10:28 AM Thread Starter
OneSLOW10's Avatar
Thanks again C. Your comment should be a sticky so it helps others. After C brought in the T 30 it took about 5 mins to take off the oem plates and install the IVANS. Piece of cake..
post #5 of 5 Old 04-26-2008, 05:43 PM Thread Starter
OneSLOW10's Avatar
to BD or whoever else. I seen BD's KLEEN removal system how to. When I did the ivans install I only put in the new block off plates, removed the piece that sat in between and connected to the emission plates, along with capping off the front of the airbox where the thicker hose went. Left out of the Ivans kit was a screw, small black cap and a red screw cap. I looked at the paper that was with the Kit and depending on which bike you had depended on which piece you used, if I read it right. Back to BD's post. I noticed from his picture that I did not take out the charcoal canister and hoses. How bad is it that I did not realize and do that? - I didn't start the bike yet since I have other issues preventing me from doing so.
thanks
Ivans block off kit OneSLOW10 Performance and Tech 40 05-04-2008 08:37 PM
F/S....04/05 Ivans TRE lunitk Parts, Gear and Accessories 6 04-18-2008 12:43 PM
ivans tre bodyglove Performance and Tech 3 12-06-2007 09:34 AM
FS:06' 10R Ivans Block Offs, APE Valve Springs deezuhl Parts, Gear and Accessories 17 09-22-2006 05:57 AM
Ivans TRE LordBadly Parts, Gear and Accessories 5 05-17-2005 10:13 AM
