Ivan s TRE ZX10 04 05 - Kawasaki ZX-10R.net
post #1 of 9 Old 06-10-2010, 11:02 PM Thread Starter
theatiss's Avatar
Today I used the TRE of the IBAN, but the FI lights on
According to the damage the sensor speed is fault
Does anyone know what s going wrong??
theatiss is offline
post #2 of 9 Old 06-11-2010, 01:27 AM
tasos's Avatar
Did you choose the correct wires to plug it in?
tasos is offline
post #3 of 9 Old 06-11-2010, 01:36 AM Thread Starter
theatiss's Avatar
at the GPS connector i choose the black and the green with red stripes wires
theatiss is offline
post #4 of 9 Old 06-11-2010, 01:55 AM
tasos's Avatar
Ii think they are correct. Make sure the pins are touching, it's tricky there.
tasos is offline
post #5 of 9 Old 06-11-2010, 02:02 AM
tasos's Avatar
Here are the instructions for Ivan's:
1) Remove fuel tank & airbox
2) Locate GPS connector at bottom of fuel rail on left (green 4 wire connector) and release from fuel rail. (you will need to depress the release tang)
3) Separate connector and remove the 2 wires (green w/red stripe and black) from the female end of the connector (the end with the male pins)
You will need a sharp pointed implement to depress the latches that hold the pins into the connector.
4) Install the pins that were removed from the stock connector into the supplied connector.
a) When installed correctly, you will hear a click when they seat.
b) Pay attention to their orientation as they will only fit when in the proper position.
(if you force them they will get damaged)
c) It does not matter which side of our connector the green/red or black wires are installed on.
tasos is offline
post #6 of 9 Old 06-11-2010, 02:04 AM
tasos's Avatar
Also did you asked me about the race intake cam?
tasos is offline
post #7 of 9 Old 06-11-2010, 04:37 AM Thread Starter
theatiss's Avatar
no i didn t
theatiss is offline
post #8 of 9 Old 06-13-2010, 03:01 AM
dynagrego's Avatar
Does Ivan's support center exist??
dynagrego is offline
post #9 of 9 Old 06-13-2010, 03:49 AM Thread Starter
theatiss's Avatar
i send to the european support center exist
theatiss is offline
TRE ivan biljeek The ZX-10R 2 11-23-2008 06:29 PM
Custom map for IVANīS TRE Deagol The ZX-10R 4 09-15-2008 03:03 AM
Ivan TRE Installation and Fuel Injection Indicator Light wattgn Performance and Tech 6 11-06-2006 11:19 AM
Ivan TRE Throttle sensor question... sneaky Performance and Tech 35 10-18-2006 01:37 PM
ignation module + ivan tre biljeek Performance and Tech 1 10-12-2006 04:53 AM
