intermitent problem - Kawasaki ZX-10R.net
post #1 of 5 Old 08-17-2008, 09:41 AM Thread Starter
limegreenbloodz's Avatar
intermitent problem
Hi,I have an intermitent problem on my 06 zx10 (10500miles on it) that started 2 weeks ago ,it started last time when I went to my trackday.when I go for a ride my bike seems to die sometime not all the time but yesterday I made a 5 hours ride and it only happened once.I was at about 80-85mph in 6th gear and then wanted to overtake the car in front of me so I accelerate just a little and then the bike started to hesitate gas no gas gas no gas...gas..gas.no gas like if my fuel tank was almost empty but it was full,the engine did not stall it just stopped pulling for 3-4 sec then pull for a sec. then stopped for another 4-5 sec etc...so I was slowing down and down and then power again.the whole thing last approx. 5 to 30 seconds everytime.there are no fuses blown,the bike is full of power,my bike is stock,I have changed the spark plugs and air filter for a K&N,changed the oil and filter.but there is one thing that is bothering me is the relay box above the ECU,I can hear one of the relay buzzing and it's loud enough,there are 4 relays in this box (fuel pump-headlights-fan-starter).so I thought maybe it's the fuel pump relay that's buzzing and when the problem occurs the fuel pump relay stopped working?what do you think guys?
limegreenbloodz is offline
post #2 of 5 Old 08-17-2008, 09:42 PM
Wind Draft's Avatar
do you have the tre? mine was doing something similar... i would gun it in 2nd and it would hesitate for quick moment then take off. And this is with the tre setting at 1 full power basically.
Connectors could be loose or whatever...not sure..
Wind Draft is offline
post #3 of 5 Old 08-18-2008, 12:17 AM
bugman53's Avatar
sounds like fuel starvation to me
High Velocity Cycles 2005 Ti ZX10R
Greeensboro NC
bugman53 is offline
post #4 of 5 Old 08-18-2008, 12:28 AM
inappropriate
hesaves0211's Avatar
Images: 67
sounds like a bad ground or a recessed pin from the fuel pump. get a multi-meter, im sure youll find it. i had a similar prob and thats what i found. the pump is ground to the seat support brace, and if that screw comes loose youll find that under hard acceleration your weight shifts around that seat mimicking your faults.
1ST GEN-10R 234hp/[email protected], GT2871RS, cometic gasket, tial bov/ex wastegate, BEGI FMU, WALBRO fuel pump,falicon clutch basket,race pak clutch,200/50 pilot,yana-shiki levers,.net wristband, WEGO III,PC3,GPR damper,cbr cals/Galfer SS brake lines,gp shift,1/5 throttle, 2NDARIES REMOVED <<click for how-to, *R.I.P D.J 10 Apr 04*
hesaves0211 is offline
post #5 of 5 Old 08-18-2008, 08:07 AM
SkyDork's Avatar
All of the answers given are valid areas to be concerned with and to certainly check out. But there's another area that's not so obvious.
My '06 was doing almost the same exact thing as you just described. I'd be rolling down the highway at 80mph and the motor would just shut off for no apparent reason. About 5 secs later the engine would come back on, and act like nothing was wrong. A minute later - dead. 20 sec later - fine. I pulled over on the side of the road and started messing with it thinking there was a connection loose or something.
Turns out it was the sidestand safety switch. The housing had rotated forward on the single mounting screw and while it appeared as though everything was fine, the switch was rotated forward just enough that the switch was intermittently making contact and telling the ECU the sidestand was down. A small bump, wheelie, or even a hard acceleration would cause the bike to die. I fixed the problem by rotating the switch housing back into the proper position and safety wiring it to the sidestand spring mount. Problem solved.
#WordCrimes
SkyDork is offline
PC III problem ??? HELP ninja_12r2000 Performance and Tech 12 05-29-2007 09:27 AM
FI problem Funaru Performance and Tech 1 03-30-2007 02:01 PM
This is a problem!!!!!***NWS*** ninjamaster6-10 Adult Content - Photos / Videos - N.W.S. 15 11-12-2006 05:04 PM
Anyone have the same problem as me??? brianhknott The ZX-10R 18 11-15-2005 04:55 PM
Uh oh....problem. Jay Performance and Tech 10 08-21-2005 01:34 PM
