Interesting problem on my '05 - Kawasaki ZX-10R.net
post #1 of 19 Old 05-04-2008, 02:38 PM Thread Starter
lavudyar's Avatar
Send a message via Skype™ to lavudyar
So I'm putting her back to stock today in preparation for selling her (possible '08 on the horizon? I think so!) and before yanking the Sato full system I start her up and let her run a bit just to enjoy the sound. Afterwards, I pull the Penske and drop the stock shock in then attack the exhaust system.
To make a short story long, I put the stock exhaust back on, attached the exhaust valve cables and tried to start her. Well, she ran for about 3 seconds then died - now, I was very low on fuel and I figured she finally ran out. So I dropped a gallon in and still no joy, though she backfired once. Finally, I pulled the Power Commander off so she's 100% stock now and still won't start. She turns over fine, the fuel pump makes all the right noises and I check all the fuses. Also, when turning over a fine, unburned mist comes from the exhaust.
It sounds like there is no spark - no popping or attempt to start at all. Any ideas?
Ray D
Never pet a burning dog.
lavudyar is offline
post #2 of 19 Old 05-04-2008, 02:48 PM
maybe the cables are on backwards, although i dont think that would be a reason to not start.
diagnose step by step. start by taking the exhaust off, start it, if it doesnt work then move on to something else that you may have messed with.
ixotuckeroxi is offline
post #3 of 19 Old 05-04-2008, 03:18 PM
thrill's Avatar
exhaust butterfly may have seized up in closed posi. Take the seat off so you can see the actuator & check if it is cycling when you turn on
Bill - GI Pro, Hindle slip on, Smoked screen, ZX14 brakes.... Well, you feel lucky, punk? You shouldn't, this is a 10R
thrill is offline
post #4 of 19 Old 05-04-2008, 03:27 PM
kawiiiiii's Avatar
Images: 19
Chech the fuses first
kawiiiiii is offline
post #5 of 19 Old 05-04-2008, 04:13 PM Thread Starter
lavudyar's Avatar
Fuses checked (see 1st post) and I re-disconnected the exhaust butterfly so it stays open (the servo is moving though), still no joy.
As for re-checking everything, I pretty much did that and all connections are good.
The truly strange part is that this happened after changing out the exhaust - no other components involved and it was running fine before that.
Could it be flooded? If so, how do you un-flood a FI bike?
Ray D
lavudyar is offline
post #6 of 19 Old 05-04-2008, 05:58 PM
Nukedog's Avatar
There is a short or open somewhere...
09 R6S Slow and steady...
USN Retired *1987-2007*
IYAOYAS
Nukedog is offline
post #7 of 19 Old 05-04-2008, 06:44 PM Thread Starter
lavudyar's Avatar
Gawd I hope not, though I do have the extended warranty so if I can't find the problem it'll still get fixed free.
Still, where would the short come from all of a sudden like that?
Ray D
lavudyar is offline
post #8 of 19 Old 05-04-2008, 09:41 PM
greencheezeeta's Avatar
Are you running iridium plugs? They foul up really easy. Happened to a friend's 07 10r. Same mist and occasional pop. New plugs fixed it right up.
greencheezeeta is offline
post #9 of 19 Old 05-04-2008, 09:45 PM
saki10man's Avatar
Images: 14
Send a message via MSN to saki10man
try pulling all plugs and cranking engine, I would drop in a new set of plugs while in there, hope this helps
saki10man is offline
post #10 of 19 Old 05-05-2008, 02:40 AM
FI light on? Do you have a service manual?
You've apparently checked for fuel and have it. The next old-school step would be check for spark. I ask about the FI light and manual, because you can put your bike in "Diagnostic mode" and see if it's throwing any faults. Your manual will tell you how to do it, and it involves counting your FI light blinking.
I guess you could also re-install your Sato, and see if it runs with it.
Advanced Kawasaki is offline
Very Interesting gpz1100 The Out House 5 02-08-2008 02:01 AM
Interesting gpz1100 The Out House 2 02-07-2008 11:45 AM
Interesting kit car gpz1100 The Out House 17 10-24-2007 10:30 PM
interesting bit................ Big Daddy Track 7 10-11-2007 11:34 AM
Interesting vid yamadak13 Pictures and Videos 12 05-15-2007 08:19 PM
