installing exhaust - Kawasaki ZX-10R.net
post #1 of 4 Old 11-20-2008, 12:24 AM Thread Starter
sam_b03's Avatar
installing exhaust
I found a used in good shape Akra full system for my 07 10r. Am I going to need to get gaskets to get it installed? Sorry for the newb queston, but I have never installed pipes on a bike before and the my local dealer is a POS that doesn't even stock air filters.
BTW my bike has little over 10K miles on it.
War is about killing people and breaking things. It ain't the olympics. Its not supposed to be fair. Tom Clancy
ialsodontknowwhynewpeoplecantseperatetheirthoghtss owecanreadthemitmakesitunweidlyandannoyingtryingto decipherwhattheyaretryingtosaysoiusuallyjustmoveon atleastyouusedpuncuationthoughsocongratsonthatbutm aybeinthefutureyoucanhelpusalloutbecauseyouoranyon eelsewillgetmorerepliesifyoudontwriteonebigrunonth atsimpossibletoread
sam_b03 is offline
post #2 of 4 Old 11-20-2008, 12:33 AM
thrill's Avatar
Given the low cost of flange gaskets, it is worth replacing them. Once they have been used, they should not be used again as they crush to provide a seal
Bill - GI Pro, Hindle slip on, Smoked screen, ZX14 brakes.... Well, you feel lucky, punk? You shouldn't, this is a 10R
thrill is offline
post #3 of 4 Old 11-20-2008, 12:42 AM
thrill's Avatar
I havent ever had to remove the pipes of my ten yet, but I guess they are the same as all the others. Make sure you note the way the retainers go back in. They are the half round bits with a flange lip. The lip goes to the front. ie the wide part away from the motor. A moron mechanic refitted my old gixxer 750 pies the other way, and the retainers just slid inside the flange and didn't tighten the pipes against the ports
thrill is offline
post #4 of 4 Old 11-20-2008, 12:47 AM Thread Starter
sam_b03's Avatar
Thanks I didn't now. Some manifold gaskets are reusible on cars. I just wanted to see if mine were good or if I need to order some gaskets so that they might get here when the pipes do.
sam_b03 is offline
Installing my stock exhaust again on my 07 zx10r... have some ???'s... Neversatisfied02 Performance and Tech 18 08-31-2007 06:05 PM
Installing 520 kit, how to sumjoeguy Performance and Tech 4 06-05-2006 03:19 PM
need help with installing a new exhaust system R1 killa Performance and Tech 10 02-02-2006 08:48 AM
Installing new grips zx102nv Performance and Tech 7 01-06-2005 08:20 AM
need help installing 16t zexxx04 Performance and Tech 12 01-03-2005 10:28 PM
